Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
How can the latch be fixed - Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
My 2001 gmc envoy hood won't close, it hits latch and safety latch only one holding it closed
Use some wd40 and spray in the latch assembly,now get a screw driver and manually pull/pivot the hood release cable back,now put a new extra spring on the pull cable arm on the latch assembly after you have loosened the latch cable parts in the latch,now spray more wd40 in the latch.
This is the fix 90% of the time.
Apr 10, 2017 | GMC Envoy Cars & Trucks
2002 Bravada hatch stock in lock position
if latch is down in secure position use a key or screw driver to reset it the following shows how to reset latches
FIX CAR DOOR LATCH if the latch is damaged internally will need to remove he panel and examine the rods and or springs for damage or disconnect and as to worrying about a dead battery undo the fuse or relay
Oct 01, 2016 | 2002 Oldsmobile Bravada
Door wont latch
FIX CAR DOOR LATCH - YouTube
? 1:29
https://www.youtube.com/watch?v=wmWsM-TSaKo
Oct 21, 2011 - Uploaded by benherrerajr
Ever had a car door that wouldn't close? If the latch was accidentally stuck down, then here's the most ...
DIY Fix & Repair For Car Doors That Will Not Close
finley.xyz/diy-fix-repair-for-car-doors-that-will-not-close/
You are out and about and your car door suddenly won't close and stay shut. ... should be your first go to choice for repairing a car, truck or vehicle door latch of ...
Car Door Won't Close or Stay Shut - JamesMaurer.com
Jan 16, 2016 | Cars & Trucks
Cable is let go at the latch hood release now how can i open the hood so i can fix it
I had the same problem on a 1993 Buick Lesabre. I could not pop the hood using convention methods(handle on driver side). I have good news . . . in my case it isn't nearly as difficult as I had researched. It turns out all I had to do was take a flat screwdriver underneath the car to reach the latch from behind the radiator. First take the grill off. Once you get the grill off you will be able to see from the front where the latch is. It will be nearly centered from the front of the hood about 10 inches back and 1 inch below the top of the hood. If you look carefully you will see a hole in the middle of the hood latch device. In my case I could not pop the latch from this hole from the front(although I hear it may be possible). Once you find the latch from the front grill side, go up underneath the car and reach up from behind the radiator with your flathead screwdriver and try to feel for the latch with it. You may need to be VERY patient because you will not be able to see what you're doing. Don't drop your screwdriver.
After I popped the hood, I found that the latch had simply become dislocated and was an easy fix. The whole fix took about an hour. About 30 minutes to find the latch from underneath the car and about 30 minutes fix it.
Oct 30, 2011 | 1991 Buick LeSabre
Were can I get my trunk fixed, it won't latch? 96
Any repair shop (body shop or auto repair shop) should be able to handle trunk repair. You may want to look through your local yellow pages. Have you tried spraying a lubricant into the latch assembly, sometimes it help to lube it and use a screw driver to flip latch/lock to locked position and then release with key or trunk release button several times. Rust is prone to jam locks and latches. Most local auto parts stores carry these latches in stock, and it is relatively easy to change out. Let me know if you need further help.
May 25, 2011 | 1996 Pontiac Bonneville SE CA Value
My 2005 chevy Avalanche tailget will not latch.how do you fix it?
I assume the tailgate is in alignment and hasn't been in an accident. If that is good, then probably the latch mechanism or the latches themselves are plugged up with dirt or rust. Liberally spray WD 40 on both latches and inside latch mechanism. Work the latch to see if that frees it. If not, then you likely have something broken in the latch mechanism or the springs in the latches.
Jul 10, 2010 | 2004 Chevrolet Avalanche
Drivers side seat belt will not latch or even go all the way in to latch due to the latch mechanism staying closed. Is there a fix for it or does it just need to be replaced?
You really should just go to a salvage yard and purchase another latching mechanism, for safety reasons prying and shoving a screwdriver into the latch can be a temp fix that could interfere with safety later on down the road when you really need your safety belt...
Apr 03, 2010 | 1998 Chevrolet Cavalier
The rear wind latch
yeah check the latch itself open up the latch by pulling out the latch with a screw driver then try agian.
Mar 07, 2009 | 1997 Isuzu Rodeo
Film door latch is loose
Same advice I made to another post. At some point you got to make a decision. There is a lot of plastic pieces that can break. Canon doesn't support the T series from what I've read. You may consider getting another one. You also have to consider that the fix may not work. Then what do you do?
Sep 06, 2008 | Canon T70 35mm SLR Camera
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
