Question about Home Security
Were can I find the manafacture of Swallow electronic digital safes
I have a Swallow electronic digital safe for which I can't open I have put in my numbers but I have lost the key for it their is a new battery in dose anyone no the manufacture address or e-mail address ?
dmathwizard
  • 113 Answers
SOURCE: small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Posted on Mar 05, 2008
  • 7 Answers
SOURCE: I have a Nutool SF10 electronic digital safe and
You will need to either break it open, or go see a locksmith.
Posted on Sep 18, 2009
SOURCE: Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
Posted on May 29, 2010
SOURCE: unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Posted on Aug 08, 2010
SOURCE: Detroit electronic digital safe lost code and keys
Help, just boughta Detroit digital safe, code number to open my instructions are locked inside.
Posted on Aug 20, 2010
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    Have key and code...safe will not open
    Sentry Safe not unlocking - YouTube
    ? 0:36
    https://www.youtube.com/watch?v=4mbtSUAoS6w
    May 8, 2013 - Uploaded by 1diazsantana1
    When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
    Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
    idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
    May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
    Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
    Opening the Gordon Digital Safe #45891 with dead batteries.
    Just did this with my same safe for same problem. It worked! Great..just pulled the whole front off first but whatever!
    Mar 18, 2010 | Safe International Digital Electronic Safe...
    I cannot open safe with the usual code.Safeguard electronic digit
    To open a Safe International Digital Electronic Safe
    User override key to open safe
    Then:
    a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
    b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
    c. To change code repeat step a.
    Test your new code before closing safe.
    Apr 27, 2009 | Safe International Digital Electronic Safe...
    Home Security Logo
    80 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
