Question about Frigidaire ATF6000ES Front Load Washer
WON'T START, WATER DOSENT FILL
DISPLAY SHOWS CODE E1
  • Frigidaire Master
  • 5,323 Answers
IN LET WATER VALVE
Posted on Mar 31, 2015
Hi. Can you tell me what E1 means on the display
LG Dishwasher Error Code E1 How To Clear
Based on your model number ... it is probably an LG appliance.
Use the link above to learn about the E1 error code. According to the web site ... there is a chance that nothing is broken and the code may have been caused by how the dishwasher was loaded. The web site lists 7 reasons why the E1 code came on.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Dishwashers
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What is E1 error code
    The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
    Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
    Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
    Hi, this is what the error code means,
    E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
    When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
    When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
    Normal thermistor resistance values:
    60 degrees F. - 15.3K ohms.
    70 degrees F. - 11.9K ohms.
    80 degrees F. - 9.2K ohms.
    Hope it helps.
    Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
    LG dishwasher error code E1
    E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
    Nov 21, 2017 | LG Dishwashers
    E1 error code on my kenwood dishwasher [kwd243a
    Hi
    The E1error code indicates a water inlet error.
    To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
    If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
    If inlet valve has tested OK ie machine filled with water in test mode then:
    Disconnect from power.
    Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
    - Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
    - If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
    - If you still have problem, then control board is faulty, it is much more likely to be flow meter .
    Thanks for contacting fixya.com
    Sep 10, 2009 | Dishwashers
    E1 error code
    Fault is 1E- this indicates a water inlet error.
    - If you still have problem, then control board is faulty, but in my experience it is much more likely to be flow meter
    Aug 05, 2009 | LG Dishwashers
    I have a Kenwood KDW12ST3A that intermittently shows E1 Thank you in advance for your help.
    Hi
    E1 means no inlet pressure. Sometimes fault code shows if machine takes too long to fill. Kindly check for blockage in inlet pipe. Also check if water inlet is not filling and check if the water outlet valve is opening and there is sufficient water pressure.
    Please do rate the solution as "FixYa" and revert for any clarifications.
    Thanks
    Rylee
    Apr 16, 2009 | Dishwashers
    Bosch
    f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
    Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
    Frigidaire ATF6000ES Front Load Washer Logo
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
