Question about Dryers
My cabrio dryer has no power
All thermals and stats are ok
4 Suggested Answers
  • 2468 Answers
SOURCE: I've got a Whirlpool AWZ3413
check for the thermal fuse on the blower wheel housing,it will be about an inch long by 1/4 inch wide it will be white in color with a plastic body and attached to the housing by one 1/4 inch hex screw and have 2 terminals on each end,as for the other thermostats in the unit you can bypass these with a jumper wire of the appropriate size to test them individually,but if you have no heat at all then these would show open all the time,just if you have heat then it goes uot,then it could be an intermittant thermostat,the thermal fuse is a one shot fuse,when it opens you need to replace it
Posted on Nov 21, 2010
Jahn27
  • 1554 Answers
SOURCE: Whirlpool Cabrio model WED6200SW1 clothes dryer
There are two thermistors (thermal sensors) in this dryer; one is the outlet thermistor located on the blower housing and the other is the inlet thermistor located on the heating element housing as an integral part of the high-limit thermostat.
These thermistors are negative coefficient type and monitors the dryer temperature on their locations according to their resistance which varies inversely with the temperature. The resistance drops as the temperature rises and rises as temperature drops.
One or both of the thermistors has an open connection or high resistance which makes the electronic control board thinks that the dryer temperature is low no matter how high it is. The electronic control board then doesn't cycle the heater relay and continue to turn on the heating element. The dryer temperature continues to rise and this blows the thermal fuse.
Make sure the thermistors are connected snugly. Remember that loose or open connection means high (infinite) resistance which makes the electronic control thinks of low dryer temperature. Measure the resistance of each thermistor then refer to the tables below. Replace the thermistor if the resistance reading doesn't comply with the table.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Mar 02, 2011
scottkublin
SOURCE: whirlpool cabrio dryer has power but won't start
I had the same problem. It's as simple as a piece of plastic that broke off from inside the user interface housing which is what depresses when you push the start button. Since it broke, clicking on the start button did nothing.
To fix it, I just superglued the piece back together and it works perfectly again.
Posted on Sep 17, 2012
Bosch dryer will not heat
If you have a Tumble Dryer that is not heating up but the drum is turning ok, then the chances are the thermal overload cutout has tripped. Bosch dryers have a reset button but you will have to remove the heater cover panel to access it, you will find it just above the heating element (a black stat with small red button) simply press the red button and if it clicks you've fixed it.
It also may be:
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced
Dec 13, 2013 | Bosch Nexxt 800 Dryer
Operating Thermostat Burnt out Twice
have you checked the venting ???? the heat could be backing up into the dryer causing it to burn out.?? Run a load with no vent on and see if it is ok..JUST a NOTE:the operation(cycling) stat the Hi limit Stat and the Thermal cutoff are all diffrent The Thermal cut off is located on the upper part of the heating element housing...The hi limit is on the bottom of the element by the terminals to the heating element.. the cycle stat is on the exsh. ducting I just wanted to make sure we were talking about the same part
Jan 26, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool electric cabrio dryer no power
change relay board top board under lid upside down left side of dryer
Nov 30, 2013 | Dryers
Dryer runs, no heat, element OK 10.5ohm, Hi limit thermostat .8 ohm, next one is thermal cutoff or operating thermostat, open no meter readings. Part # FSP 3399848 could this be my problem? Thank You
Both the Thermal cutoff and the operating t-stat should have ZERO ohms resistiance 0.8 is fine but open on either they are bad
That part number you have listed is what ya would need..even if only the thermal cutoff is open replace both the thermal cutoff and high limit t-stat at the same time
also if the cycling t-stat is open replace it too...if its fairly modenr and hasa digital display the cycling thermostat is a thermister and at room temp that will be about 5.8 thousand ohms
if has timer the cycling t-stat will look like the high limit t-stat and should be closed
GENE
Aug 29, 2011 | Dryers
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
Cabrio electic dryer has power but will not run
There is a thermal fuse wired in series with the motor and if it is blown, power to the motor is cut and cannot. No dryer function works when the motor cannot run. The thermal fuse usually blows due to a failed exhaust thermistor. Check for clogged lint filter and/or restricted vent system then replace both the thermal fuse and the thermistor if the thermal fuse is found blown open. This is a DIY repair which only requires very minimal effort with a screwdriver.
Disconnect power then remove the back panel and locate the thermal fuse and the thermal fuse on the blower housing.
Click on the link below for some troubleshooting information before replacing the thermal fuse and the thermistor.
Kenmore and Whirlpool Dryers Not Starting
Jun 17, 2011 | Whirlpool WED7300XW Dryer
Hotpoint wd 64, wash ok tumble not heating
take top off and you will see dryer manifold going across the top of machine. there are various stats mounted on the manifold. one or more may be a resettable stat ie has a small button in the middle top of the stat. press button and stat will reset. some hotpoint have instead, a thermal fuse mounted on top of the manifold in a sleeve. this may have gone open circuit so check with a multimeter
Sep 10, 2008 | Hotpoint Dryers
Maytag pyeg4500 no power
The thermal cut-out is located on the right side of the heater unit.This will kill your power. Change the t-stat also and check that your vent system is clear.
Dec 09, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
21 people viewed this question
Top Dryers Experts
