Question about RCA DCM315R Modem
Need power adapter for an SP-645ME-A1, MODEM ADSL 645ME-A1 Sprint
What power adapter voltage and amp output needed for a Zyxel/Sprint 645ME-A1 modem? The modem case does not indicate power adapter requirements and original power adapter is lost. Thank you.
Found the answer on DSLDepot.com.
Posted on Jun 23, 2009
  • drewyah May 22, 2011
    Input 120vac 60hz 18watts
    Output 12vac 1 amp
    part number 30-112-122204
  • Brent Carpenter
    Brent Carpenter Sep 09, 2012
    thanks drewyah
Bsnl broadband modem
Indian Telecom gaint Bharat Sanchar Nigam Limited (BSNL) has introduced 4 types of ADSL Broadband Modems(ADSL Basic Modem(CPE), ADSL WiFi Modem, ADSL WiFi-TA Modem & VDSL WiFi Modem) with Ethernet, Wi-Fi , USB, and Terminal Adapter port.
Which version have you got?
Feb 10, 2014 | Acer Computers & Internet
How to set up zyxel NBG416N in universal repeater mode
Yes Zyxel nbg-416n does indeed support repeater mode but you need to make sure you have at least firmware version v1.00(USA.5)C0 and you can switch to that mode via maintenance/sys op mode.
Jun 14, 2012 | Zyxel Communications NBG416N 11N 150N Wlan...
My Sprint 645 DSL modem (Zyxel SP-645M-A1) recently started freezing. My connection to the Internet stops every 10 to 15 minutes. Rebooting the DSL modem gets it working again. I can still connect to the...
That model of modem was made with firmware specifically for Sprint so ZyXEL would not have any more recent firmware for the unit. That model has been discontinued for some years now and judging from the type of behavior it is showing the unit may be experiencing a hardware failure. Your best option would be to try and find an inexpensive ADSL2+ modem to replace it with.
Feb 20, 2011 | Zyxel PRESTIGE 645M-A1 (91-004-233005)...
Power requirements for an Efficient Networks SpeedStream 5360 Ethernet ADSL Modem. I need to get a replacement Power Supply.
You need a power supply which converts AC to 12Volt DC power.
While purchasing Please keep in Mind that the ADSL power IN socket should be matching with the new Power adapter.
Oct 31, 2010 | Efficient Networks SpeedStream 5100 Modem
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
Will this modem work with SBC/ATT ISP?
Yes this one should work, you just need to get your ISP settings for this modem from SBC/ATT and configure it to the modem....
Dec 29, 2009 | Zyxel PRESTIGE 645M-A1 (91-004-233005)...
Driver Paradyne 6205 aDSL Modem 6205-A1-000 for win 7
if you can see a vista driver downloadable from the manufacturer's site, it will work 80% of the time.
Nov 06, 2009 | Paradyne Hotwire 6205 DSL Modem...
Zyxel 600 series modem set up to phone line
You just have to perform a hard reset on the modem to erase any previous data stored. Locate the small pinhole for the reset button on the bottom of the modem box if it is not at the back. Then you need to access modem gateway to put all configuration information on modem software by typing in 192.168.0.1 in your IE browser's GO TO website box (where you type website address/URL)
NOTE: Make sure that you know your username and password for your current internet connection configuration before RESETTING modem. If you don't have this settings, call your internet provider. =)
Thanks.
Jan 02, 2009 | Zyxel PRESTIGE 645M-A1 (91-004-233005)...
RCA DCM315R Modem Logo
780 people viewed this question
Top RCA Computers & Internet Experts
Rommel Balcita
Starnley Johnwells
Starnley Johnwells
Elise Lacoursiere
Elise Lacoursiere
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
