The printer is making all the noises that it normally does but when the paper is pushed out of the printer there is no ink on it and the page is blank.
SOURCE: kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo. The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded. I have tried every troubleshooting tip in the book and still no luck.
SOURCE: Printer won't print.
sounds to me like perhaps the printer drivers are really unhappy. you'll need new ones from www.kodak.com
http://tinyurl.com/6qcpgy
SOURCE: My printer is only printer blank pages? When it
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
SOURCE: I just replaced both ink
You need a new Print Head: If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Clean the printhead, then print a test page.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: paper feeds through the printer but nothing
the problem will be on the cartridge reader. you should see if the ink disposal system is running as fluid as possible.
Check on the driver also, uninstall then reinstall it back.
