Question about Mercedes C-Class Exterior Pillar Posts Trim Set
What the right fuel prssure for a 2002 mercedse c320
  • Mercedes-Benz Master
  • 2,210 Answers
Checking the fuel pressure is a job for the trained person with the right gear. You would need expert hands on help.
Posted on Jul 30, 2014
Where is the air pump located on a 2002 mercedes c320
hi have a pic of location but cant seem to attach it or upload.
Dec 22, 2015 | 2002 C320
How can I change license plate lights on my 2002 mercedes c320
What a question and read your manual...... and don't forget to put the gasket on it's place again. I assume you didn't google first since there are plenty of mercedes forums, which also are too lazy to take a look themselves.
Mar 25, 2015 | 2002 C320
2002 c320 radio and cagarite lighter do not work.
Had the same issue on 2002 c320 . look at the fuse chart ,find out the fuse # that operate the radio and the cigarette lighter , you have three fuse boxes, engine compartment, driver left knee and trunk on left .find the fuse b compairing the char to the box , replace the fuse . DONE
Jul 01, 2014 | 2001 Mercedes-Benz C-Class
2002 Mercedes C320 very poor fuel economy ~8 mpg, no engine codes or faults present
Lead foot, tire pressures, stop /go driving. AC/poor compression, Trunk full of sandbags, transmission slipping, Wheel bearing friction, Brake shoe always on, etc.
Sep 08, 2017 | 2002 Mercedes-Benz C-Class
I'm not sure what the problem is specifically, but I can assure you this--you're basically throwing money way (and possibly exacerbating the issue) by using 93 octane fuel. Your car is timed and tuned to run most economically and with best performance with 87 octane fuel. The higher the octane, the slower the fuel burns. Longer burn time can equate to more power, but ONLY if your engine is designed and tuned for this application.
Couple of suggestions..checkto make sure your exhaust is "free". A plugged catalytic converter can really rob mileage. Tire pressure and air filter are worth mentioning as well.
Jan 01, 2013 | 2002 Mercedes-Benz C-Class
Steps to replace the fuel filter on a S500 mercedse-benz
Here is the step to follow (at your own ..legalese required) you do not even need to jack up the car. just parked the rear tire on a long 2x12.1. Remove the T relay from underneath the rear seat
2. Crank the car until it dies quickly to remove pressure from the fuel filter 3. I used a cardboard to slide underneath. once there, the fuel is located next to the fuel pump. Both a within their own plastic box right before the rear driver side tire. To remove the cover, i just unscrewed the 3 plastic bolts holding it and loosen two other screw for more wiggle room.4. Cut off the factory clamps. Start removing the 4 hoses connected to the original FF. Some gas will drip during this step. If you were smoking before, now would be a good time to stop.5. Connect new FF Don't forget to new clamps.
6. Replace FF relay 7. turn key to position 2 but do not start engine. While fuel pressure is building, go back to check for leaks.8. Put everything back together 9. Start car and you're done
Oct 09, 2011 | 2002 Mercedes-Benz C-Class
Put a used engine in my 2000 silverodo. stated right up and got great oil prssure. drove home sat over night, started next day 10 pounds of prssure at idle, rev to 1000 rpm got 40 psi of prssure. the...
have you replaced the oil sending unit. and check the wire to it, and also i would give the engine a oil pressure test while the sending unit is out, if you have good oil pressure then, i wouldn't worry about oil pump, i would still consider replacing the oil sending unit.
Feb 16, 2011 | Chevrolet 1500 Cars & Trucks
Obd 2 codes P0302-P0304-P0305-P1313-P1316 and P0778 2002 Jaguar X type 3.0
THE P0302 is misfire cyclinder 2,4,and 5
The P1313 P1316 is Cyclinder compressor low, Worn camshaft/ broken valve springs. Fuel injector contamination, Spark plug failure/ incorrect gap. Iginition coil failure.
P0778 is 2/4 Brake prssure solenoid failure
HOPE THIS CAN HELP.
Apr 09, 2010 | 2002 Jaguar X-Type
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
44 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
