Question about Honeywell Programmable Thermostat Heater
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We intend to run the underfloor heating on a 24 hour basis but stepping the temp down at night and then back up in the morning, this has been recommended. The underfloor system is isolated by a zone valve. I have 3 rooms on the underfloor system that will probably require different temps. Can you recommend suitable room thermostats for the 3 rooms plus a new room thermostat for the radiator system. Will these be programmable or do I need seperate programmers. Thanks
    President:
  • 1,723 Answers
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 01, 2009
How do I turn my Siemens RDE100 underfloor-heating off? It is in a bathroom which gets little use and electricity is too expensive to waste in this way.
Turn it off at the thermostat
Heatwell Thermostat Programming Video for Siemens RDE100 ...
? 14:49
https://www.youtube.com/watch?v=Z7NSZaTW90A
Oct 13, 2013 - Uploaded by Kiwiash Ash
Programming instructions for the Siemens RDE100 series ... Siemens RDE100.1 thermostat ... How do I turn ...
[PDF]RDE100.. data sheet - Siemens Download Center
https://www.downloads.siemens.com/download-center/download?A6V10399978 Nov 21, 2017 - The RDE100.. is used to control the room temperature in heating sy. Typical applications: Apartments ... Siemens. RDE100.. Room thermostat with Auto Timer, Option External Input ..... underfloor heating (only for. RDE100.1).
[PDF]RDE100.1RF operating instructions - Siemens Download Center
https://www.downloads.siemens.com/download-center/download?A6V10410001 Apr 18, 2017 - The RDE100.1RF consists of a wireless room thermostat RDE100.1RF which operates in ... Select Auto Timer mode for the heating period, and.
May 20, 2018 | Siemens Heating & Cooling
I need a new Rehau Thermostat CT for my underfloor heating, the current one is broken. I am located in Leitrim in Ireland.
Give eBay a look, there are several for sell there.
I would ask if they are EU compatible at 50hz. I'm guessing they are since Rehau is a Canadian company but I'd check first.
Sep 16, 2017 | Heating & Cooling
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
I have the aube TH132 underfloor heating system installed. I have programmed the temperature set points to 18c but its over heating to 43c!! I've re programmed it but with no luck!! The icon for when...
This product has 2-year warranty against defects in workmanship.
Aube technologies Inc.
Warranty does not apply to poorly installed ...
Canada 450-358-4600
Manual does not have troubleshoot section.
section 4 includes temperature setpoints by model number.
On-line manual can be word-searched for fine details that might be missed by a visual read.
http://waterheatertimer.org/pdf/TH132-A-F-AF-230-thermostat.pdf
Check that air vents are open to control, so the unit can read correct temperature.
Change temperature Display selector for F or C.
Make sure wires are connected to correct terminals to match your voltage.
15 amp max rating indicates #12 gauge wire for 120Volts. Recommend that thermostat control a contactor instead of direct-wire to heat coils.
Example contactors
http://waterheatertimer.org/H230A.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 09, 2012 | Hardware & Accessories
The emergency heat will not turn on in my system. I also noticed the emergency heat light does not turn illuminate on the Honeywell HZ322 TrueZone Panel even if the emergency heat button is pressed. The...
Yes, I believe you are correct concerning the circuit panel.
Regarding your heat pump not keeping up ...depending on what part of the country you live in, heat pumps are not the best thing to heat with. As you probably already know, once it reaches 32 degrees outside, the heat pump stops working and the electric furnace or heat strips come on to supply warm air. Frankly, when that happens, it's like turning on your kitchen toaster and blowing air across it with an electric fan. Doesn't sound to efficient does it. Plus, your electric meter is spinning like crazy and the power company is falling in love with you.
In my area (Virginia) most new home construction is now using what's called a dual fuel system. It's a heat pump, but it has a gas furnace backup for when it reaches 35 degrees outdoors. It's very, very efficient and a very comfortable heat. The gas furnace can run on either Natural Gas or Propane Gas.
In most cases this can be added to an existing heat pump system. The only thing necessary is the Gas Furnace, since you already have a heat pump and all the duct work. Could probably be added for a whole lot less than you''d expect.
The other option is to add a vent-free gas fireplace or vent-free gas logs, if you have an existing solid fuel burning fireplace. They are great for zone heating and/or supplemental heating. Plus, if you have a power outage in the middle of the winter, they'll still work, as they don't require any electricity.
I didn't mean to run own, but I hope all this helps you solve your heating problem.
Please let me know.
Rich
Feb 09, 2011 | Amana PTH123B25AJ Heat Pump Air...
I want to upgade from my old water tank to a tankless water system. I have underfloor heating and it has 4 zones but i run it as one zone and it is controlled from a therm ostat that controlls a pump.I...
what you have is called a hydronic heating system.
this heating system is completely isolated from your water heater I believe this as most hydronic systems I have installed circulate water through the furnace to heat the house. If this is true you need only to connect your old water heater cold water supply side to the tankless and, old hot water side to the house system: the showers/tubs/sinks etc. in your home.
my appologies if I have missunderstood your inquiry.
Jan 26, 2010 | Rinnai Digital Remote Water Heater Control...
We have a robbens underfloor heating system with a heatrae electric boiler on a floating floor system. The underflooe heating manifold has a grundfos Alpha + pump. What setting should this be at? Currently...
Venting of the system is when you re circulate the water or cooling fluid in higher speed to eliminate the air bubbles from the system.
If water circulate on a too higher rate does not have time to dissipate the heat so your floor is cold.
You need to go to 2 or even 1 depending on the length of the heating coil in the floor. Unfortunately the pump only has 2 speeds (setting 1 and setting 2) so whoever install your system had to calculate the length of the pipe for maximum efficiency. Try on 2 and if not satisfactory go to setting 1. If too hot on setting 1 then you can adjust the heat by reducing the amount of water from the shut-off volume control. It is a hit and miss situation, I know but unfortunately that is the only choice remaining now after the system is installed.
Jan 10, 2010 | Grundfos RCP-96 Recirculation Pump for...
Honeywell ST6400C programmer doesn't switch off
Since you have three on/off timing modes could there be an overlap in the times?
The wires in the unit might be crossed. (don't always assume the contractor who wired maintained the correct colors , I have a friend who blew out a heating pipe because when a replacement motor valve was installed it was never wired right and the plumber assumed the colors were correct so no overtemp shutoff created steam in PVC pipes, OPPS)
There fore maybe one is still coming on. Do you have more than one heating zone? IF so see below
I guess the main question is why manually turn it off? why not use the program.
I will assume your heat is know as forced hot water heating. My house is multizoned however when the zone calling for heat turns off (zone valve closes) I installed a bypass valve in the lowest zone in the house, and reduced the circulator low shut off temp to 130 F which means even though the heat isn't on my circulator will continue to run dumping this excess heat in the lowest part of house to rise through house. (the spring loaded water valve allows the heated water to flow into this zone )We do have two thermistats. And even though the lowest one is not calling for heat the radiators are hot when the excess is dumped into this zone. So investigate and see if your system might be similar. (multizone).
Investigate your wiring, reprogram, replace any battery backup.
Dec 18, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
364 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
