Question about HP Office Equipment & Supplies
Continuous ink supply "faulty ink cartridge" - HP Office Equipment & Supplies
    Master:
  • HP Master
  • 406 Answers
Change the ink cartridge
Posted on Aug 12, 2014
Hp dj 800 ink supply station not recognize black cartridge
Does it show a Flashing X for the Black?
1 Replace the Ink Cartridge that has failed.
2 If the message continues to appear, clean the electrical contacts
inside the Ink Supply Station (power OFF the Printer first).
3 If the message continues to appear after cleaning the Ink Supply
Station, replace the Ink cartridge again.
Mar 09, 2014 | HP DesignJet 800 Printer
Reset ink levels
If you're referring to the OEM/Original cartridges the short answer here is "You can't!".
However you can opt for alternative ink supplies in the form of Refillable Cartridges or CIS (Continuous Ink Supply) systems as these use Auto Reset Chips (ARCs) to reset the ink level.
Obviously you have to make sure they really are full of ink but it's a much simpler approach than trying to reset original cartridges.
Hope that's of some help.
Jun 23, 2013 | Epson NX415 All-In-One Printer
I recently made my canon iP2770 a continuous ink one. It as going well, untill it said "The holder is in the ink cartridge replacement position.Close the printer's cover.Ink has run out. View the
Throw it in the trash and buy a laser jet.
People who print a lot, and do I, would be better off buying a new printer every time I went to buy cartridges.
The printer I bought was a brother HL 3140 cdw.
~$200 at staples
The cartridges are expensive ~$200 and lasted me for a year.
I said a year!
Jan 27, 2018 | Canon PIXMA iP2200 InkJet Photo Printer
I replaced colour ink cartridge and it continuous to say replace colour ink cartridge
Mine did that and the new ink catridge was faulty. I purchased another one and it worked just fine. Found out this has been a problem with cartridges quite a bit. Hope this helps.
Oct 21, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hello I have replaced ink to the printer and i have this error num 10000160 do you have solution to this problem. I try to reset without results. Itzik
Many of the Epson printers ink cartridges have a sensor thatallows the printer and the associated software knows when to replace theprinter ink cartridges (even when the cartridges have ink within them) and whenthe printer needs to be cleaned. You mayreceive error messages if that sensor is faulty. In that case you shouldreplace that sensor. Hope this will help you. Good Luck.
Aug 24, 2011 | Epson Stylus Pro 9800 InkJet Printer
Errorcode 93:11 on HP designjet 4000
Unable to pressurize the IDS(ink delivery system). Ink Pumping problem.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the
Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing
Cable
Jul 15, 2011 | HP Designjet 4000ps InkJet Printer
Hi Folks: I would appreciate any help and suggestions: HP DesignJet 1055CM error 0A0020 006501D1 Thanks, Paul
"Error in calibrating the APS sensor"
APS= Air Pressure System - it provides air pressure to pump in to the ink cartridges, thus pumping ink to the printheads through the ink tubes.
First things to try
- Remove all Ink cartridges.
- Power down printer.
- Power on.
- Place cartridges in ink supply station, check if they are recognized.
- Replace the one cartridge that is almost empty.
- Check all cables and air tubes in the ink supply station. (you need to remove left cover of printer)
Make sure they are all properly connected and not damaged.
Make sure the air tubes are free running - NOT pinched or bent!
- Lastly,
When all above fails, replace faulty APS sensor and / or pressure valve.
Oct 30, 2010 | Computers & Internet
Printer has shown error 10.00.00 Supply Memory Error
Please make sure to ask a specific question.
The 10.00.00 Supply Memory Error is given when the printer can not read the information on your ink cartridges. This can be common when using non-genuine ink cartridges (non-HP).
Remove and reinsert your ink cartridges. If that doesn't work, try pressing the green button to accept the error and continue.
May 13, 2010 | HP LaserJet 2420 Printer
I need a new CHEAP printer
Epson with Continuous Ink Supply System (CISS) is my choice, you'll no longer injecting ink to your cartridge that will make your cartridge live short.
Mar 31, 2009 | Office Equipment & Supplies
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
