Avol lcd tv 19'' ramote type ande nomber - Televison & Video
5 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: I have a 19 in
try these it might help.
1.try to check the aerial connections.
2.the station may have broadcast difficulties.
try another channel.
Posted on Oct 16, 2010
bbl242003
  • 1637 Answers
SOURCE: I have a 32" in AVOL LCD flatscreen TV that has no
TV needs servicing CERTIFIED TV EXPERT HERE, follow this information I provided 3 long solutions to this issue/s Solution 1 Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com 2 Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution. 3 When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me
Posted on Jan 27, 2011
josema_sv
  • 485 Answers
SOURCE: i have a RCA remote
Please check the link below of RCA remote control support :
http://remotefinder.rca.com/default.aspx?site=rca
Posted on Mar 09, 2011
  • 6 Answers
SOURCE: i want some avol 19'
Here are some that may work, depending on the actual remote, 231, 232, 235, 256, 262, 275, 276, 279, 290, 298, 329, 332
Remote Control CODES avol 19" Multi-system LCD TV ALT 1970 REMOTE
0018 0049 0101 0131 0152 0161 0181 0193 0194 0195 0226
0320 0379 0426 0433 0465
Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
May 09, 2015 | Televison & Video
Avol mod#alt2260m remot code
I have an avol lcd tv. my tv is not operating with remote and have no remote code remote is ARC-U1 tv model is ALT2260M. Please tell me hoow to apply code and which code is ti be applied on the remote.
Dec 09, 2012 | Televison & Video
I bought avol 19 inches lcd in built dvd model number ALTD1902 , i lost my remote please help to me where i wil get remote ....
You can buy a universal remote at the dollar store for cheap and then look up the model of the TV on Google and get the remote programming code for the TV and then read the instructions on how to program the specific remote that came in the remote packaging. -OR- If you are looking for the OEM remote, I would check Ebay if I were you, they always seem to have tons of remotes and other random components you cant find anywhere else
Feb 08, 2012 | Televison & Video
I want some avol 19' lcd tv codes that works in universal remote control Lcd tv model is alt 1903m
Mar 09, 2011 | Televison & Video
My 42'' avol tv goes fuzzy for about a minute then pics up a good picture. It does this inconsistantly but from time to time.
My Friend it all depends of what type of TV you have?
DLP? -----DMD board
LCD?----- Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Digital Video
PLASMA?-------
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} X sust. Board or Y sust. Board
Feb 10, 2010 | Televison & Video
I have a lcd tv and there is no sound i think the speakers r broke how can i tell
I have a Emerson LCD TV that I can't program into my ramote control. Can you help me?
Jan 14, 2009 | Emerson EWL2005 20 in. LCD Television
Need Remote for AVOL t.v
go to www.AVL21c.com this is the company that makes the AVL Brand televisions for AAFES
Aug 17, 2008 | Sony RMT-V202 Remote Control
New problem with tv and Sony RMT-V202 Remote Control
Samsung makes AVOL you may want to try there codes. Hope this helps.
Nov 01, 2007 | Sony RMT-V202 Remote Control
Televison & Video Logo
10 people viewed this question
Top Televison & Video Experts
Electro Med Services...
