Question about HP 4250 Monochrome LaserJet Printer
HP 4250 WILL ONLY PRINT 1 COPY OF A PRINT JOB WHEN MULTIPLE COPIE REQUESTED. HAVE TO MANUALLY CHANGE # OF COPIES IN MENU ON PRINTER OR REPEAT REQUEST.
    Sergeant:
  • 220 Answers
That problem is easily solvable with a driver update.
HP has released a driver package do fix that issue
Posted on Jun 22, 2009
How can i print multiple copies of the same document with 3 pages and have the printer staple the copies in the correct groups?
In the print driver you should have the option to collate, you need to make sure that that option is on, and when you go to send the print job, you need to make sure that you adjust the finishing options in the driver to tell it to staple.
May 11, 2011 | HP LaserJet 4250 Printer
How do I print several copies of a page on my HP 3015 printer
when you click on print, you should normally get a print window where you can indicate the page to be printer and the number of copies before you proceed with the print job.
Dec 31, 2010 | HP LaserJet 3015 All-In-One Printer
Hp laserjet 4250 prints 2 copies when using excel
Go into the print properties in Excel by clicking on Page Setup on the File menu, then hit Options. Next to "Copies," change it to "1" and hit OK.
Oct 08, 2009 | HP LaserJet 4250n Printer
HP 4 Plus printing same job multiple times
I'm not an HP user but try this.
Does this work with all programs (e.g. when you try to print a page from Google) or does it happen only when using your word processing program? Which program are you using?
When you tell it to print one page there is generally a place in every word processor that will allow you to tell it how many copies you want. Make sure that setting is correct. Check your default settings as well to ensure they are set to one page.
If you don't know how to change the number of copties, go to your help setting in the program and look up "copies"
Also check your hardware setting on your printer to make sure you don't have it set to 5 copies.
Sep 25, 2009 | HP LaserJet 4 plus Printer
Using XP sp2, excel 2000 and HP 4250 printer. Any
The print settings can be different for different programs. Open Excel and in the File menu, choose Page Setup. Click on Options, and towards the bottom is a setting that says Copies. Change this to "1" and hit OK, and you should be fine.
Hope that helps!
Mar 09, 2009 | HP LaserJet 4250n Printer
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
HP 4250 DTN will not print multiple copies
if this is ran through a network which i would think most likely due to the machine then you will need to change the number of copies to be printed on the control panel on the fron of your machine as well as that will have the final say over what comes out of it.
i think it should be as follows:
press the green tick, press down, green tick on print quality.
i may be worng on where its located as not used one for a while.
if i am wrong on it the go into the information menu and print out a menu map. this will show you which sub-directory its in.
Hope this helps.
Pete
Nov 03, 2008 | HP LaserJet 4250n Printer
Printing 2 copies
Please print a configuration page and let me know if that prints 2 copies as well, If yes,
within the menu, go to configure device > printing > copies, change the copies to 1
Let me know the next update.
Oct 29, 2008 | HP LaserJet 4250n Printer
My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Sep 16, 2008 | HP LaserJet 1320 Printer
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
HP 4250 Monochrome LaserJet Printer Logo
271 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
