Question about Grundfos MQ3-35 3/4 HP Pressure Booster Pump
What do I do when the alarm light is on. . Pump is not working,it's just for hot water and up stairs
I have a dual zone heating system that has 2 Taco 007-F5 cartridge circulator pumps. Both thermostats are calling for heat, however the pump that feeds upstairs is running and getting hot, but the hot...
CHECK IF THE PUMP COUPLING IS THERE IF SO TRY BLEEDING THE RADIATORS UP STAIRS TO SEE IF U GET COLD OR HOT WATER N IF THE WATER IS DIRTY. THEY LINES MIGHT HAVE AIR IN THEM. IF U TRIED THESE N STILL NOT GETTING HOT U WILL NEED TO CHANGE THE MOTOR N COUPLING
Oct 13, 2012 | Cars & Trucks
We are only getting hot water in two of the rooms in the house
1. Are you on mains pressure2. Is the problem new. ( was it working once)If Yes could be a stuck HW washer.
May 04, 2012 | TitanNet TITANTANKLESS. COM PRESENTS THE...
I have an 2002 vw gti 1.8T. Last night my alarm went off. when i went down stairs to look at it. the light on the door was no longer blinking but the doors where locked. so i tried to unlock the door with...
the button in the fob may be stuck connecting the circuit, remove the battery and reconnect if the alarm goes off again it could be because of this.
Jul 10, 2017 | 2002 Volkswagen GTI
I have just purchased three First Alert carbon monoxide alarms. My home has a basement and bedrooms on the first and second floors. My questions stem from the installation. Should the installation...
When I worked Electrical in a Hardware store we were told by Nighthawk and f\First Alert and we told our customers that you want the detectors 4-6 feet off the floor never near a water heater or furnace since this can cause false alarms. The CO will rise, so one on each floor should be enough near a central stair if possible. Other wise make sure at least one is in the bedroom.
Mar 01, 2011 | First Alert CO400 Battery Powered Carbon...
How do you disable the high water alarm and still have the pump work. I get to much water, it would run the alarm all the time and drive me crazy.
Before considering disabling the high water alarm, consider adjusting float that sets it off. The alarm is there for a reason, if you disable it you may never know when you are overflowing.
Feb 27, 2011 | Flotec Automatic Sump Pump Float Switch
The pump alarm light is on and there is water in the tank and nothing has changed, just stopped working. Have used the bleeder and water shot out and now will not work at all. Any suggestions
Press the on/off button once to reset the alarm and once again to start the pump.
If the auto reset light is on, the pump will attempt to restart in 30 minutes.
If the auto reset light is off, press and hold the on/off button for 5 seconds.
Gary
Dec 21, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
We had to replace our hot water tank, we did this
try opening the bleeders on your radiators,one at a time starting at the one closest to the pump until all air has been expelled then close bleeder and move on to the radiator next furthest from the pump and so on.if hot water doesn't come out from the first radiator within a short time, or if you cannot hear air being forced out thru bleeder you prolly have a defective pump; have it checked/replaced by a reputable pro..my guess is that the "buzzing noise" is because the pump is defective and the electricity has no place to go.an easy preliminary check for this is to feel the pump motor while buzzing to see if it is hot, if ti is it prolly is bad
Nov 14, 2009 | Plumbing
Zoeller sump pump, outside in stairwell. Rainstorm, alarm goes off, i look out, does not seem to be running or maybe it was not sure, rain was slowing down so I silenced the alarm and went back to bed. In...
Sorry to say, but it does sound like the pump is fried. It should come on(run) when it's plugged in. The fact that the water surrounding the pump was hot is a good sign that the pump was way over-heated. Also, that oil in the water is likely from the pump. Oil is used in the pump for lubrication and to water proof the inside of the pump.
The only thing I can recommend is to see if the bottom of the pump has a removable strainer or plate, and if so, see if debris has gotten inside and bound up the impeller.
Jun 27, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
Heating not working properly on my sime super 90 combi boiler
you need 15 lbs water press,bleed air from system, primary must be bad
Mar 29, 2009 | Water Heaters
Grundfos MQ3-35  3/4 HP Pressure Booster Pump  Logo
51 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
