Question about Kenmore Elite 45986 Front Load Washer
Whirlpool WM 1900 Semi Pro FH fault
Hi I have the FH fault come up on my washing machine. I know this is to do with the water flow but what happens is that it starts to fill but only adds a little water, no where near the 10.5 gallons. It then starts the cycle and after about 20 mins the FH fault comes up. We have checked the hose, no problem there, taken the top off and the water flow is getting to the soap despencer ok.We are only using a cold. Can anyone give us any other idears?
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
What does Fh or Fh stand for
this code is for flow error , its telling you the washer hasn't detected the proper flow of water in the time allotted for it to fill up , ck your hoses for kinks and your shut off valves for being full open (they need full open) also can be a fault in the flow sensor inside washer (happens a lot with high mineral water ) it sets up hard inside the flow sensor and blocks it from working well
ohh and I have seen in one case the homes water pressure was too low for washer to work as well , but this is rare and that one case was on a well system not a city supply ,but this too is fixable as well (pun intended)
Jul 15, 2016 | Kenmore Elite 45986 Front Load Washer
Not filling
http://www.youtube.com/watch?v=_a87KTHws2M
First try turning off the machine for 30 minutes. Re-plug. If nothing happens. Disconnect from mains. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the fine filters on the machine inlet entry, they could be blocked, clean out. The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem. There is a slim tube going up from the filter area to a switch near your control board or panel; it leads to the pressure switch - it should not be blocked or leaky - ie.with holes.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on some washers.
Inlet valves can be purchased thru searching this site and fitted by you easily.
Just noted that your machine is a top load; anyways, click if helped.
Apr 24, 2013 | Hoover HTC243 Top Load Washer
Whin washing 30 min left and it stops and flashes FH
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Mar 12, 2013 | Washing Machines
It has stopped washing and is flashing FH what is the problem and what should I do ??????
First try turning off the machine for 30 minutes. Still FH? Next check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Mar 06, 2013 | Kenmore Washing Machines
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
FH FAULT CODE COMES UP ONLY AT START OF RINSE CYCLE. WATER JUST TRICKLES IN VERY SLOWLY. WATER FLOW INTO MACHINE IN WASH CYCLE IS FINE. ANY IDEAS? WHIRLPOOL MODEL GHW9250LW
Most probable case of a flow meter defect
You can access this part by taking to or three screws off the top panel in the back
Part is attached nere the water valve
White round thingy
Jun 17, 2011 | Washing Machines
We have an AWM8143 (German Made ) whirlpool front loader. The machine stopped during a wash just before the rinse cycle and is coming up with 'FH' fault on the display. The windows on both inlet...
The 'FH' fault is listed as "Water Inlet Fault" in the manual. When the windows in the inlet hoses come up with their red dots, it means that the leakage valve has tripped and shut off the water at the tap. No water will flow into the machine. This can be confirmed by first turning the taps off, then taking the hoses off at the machine end. While holding the loose ends of the hoses over a trough or sink, try turning the taps on. No water will come out. I've had the same thing happen to us. We were quoted $66.00AU per hose for replacements. I'm going to try to fix one of these hoses today. They have a sponge in them which expands when it gets wet and shuts off a valve. I'm going to try getting the sponge very wet and squishing it back down and hopefully opening the valve again. Hope this helps.
Jun 07, 2011 | Whirlpool AWM8143 Front Load Washer
I ordered and bought the control panel part for my kenmore elite front load washer but the washer is still not washing it's flashin FH
fh is a water problem,does it fill with water?....... FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1HSpZo0dW
Mar 23, 2011 | Kenmore Elite 45986 Front Load Washer
Code F1, does not stop filling, water pours out of soap tray
Are you sure it's not an F/H error?
The F/H code means the unit isn't detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. Part link to the flow meter==> http://www.repairclinic.com/PartDetail/Flowmeter/1381535?modelNumber=GHW9250MW2
If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems.
Read more: Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2006/04/09/whirlpool-duet-kenmore-he34-washer-f11-and-fh-fault-codes/#ixzz1GVNXRInv
Get appliance parts at http://parts.fixitnow.com
Mar 13, 2011 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
