Question about RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 tell no light
I have a charged battery in my Paslode im350 but the warning light in the handle is out and there is no operation
    Sergeant:
  • 206 Answers
If you have no light at all in the handle and you're sure you have a charged battery, then I would look at the battery contacts - that tool has the contacts molded into a circuit board assembly so if it is not obvious I would take it to a repair center to be diagnosed.
Posted on Jun 11, 2014
  • 497 Answers
SOURCE: My paslode IM350 fires about once every 20
by service im assuming you mean replacing the o-ring and seals/gaskets. If not do that. But if you have it may be more of an internal problem with the air valve leaking around the piston.
Posted on Aug 10, 2009
  • 131 Answers
SOURCE: paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Posted on Aug 26, 2009
  • 55 Answers
Check to make sure that the chamber is free of debris because the piston can get stuck if it is dirty it probably just needs to be cleaned and then lubricated really well and the problem should stop. Other outcome is the worse it could also be that the piston is bent and it gets hung up on itself then it would have to either be sent in for repair or to take it to a repair shop.
Hope this works
Posted on Dec 01, 2009
  • 165 Answers
SOURCE: paslode im350 will only now wrk properly when on a flat surface
Make sure the nails are inserted so that the follower maintains pressure on the strip of nails. Also, your pressure on the whole gun at an angle is probably not as great as on the flat---could lead to misfiring
Posted on Mar 02, 2010
rowdy45176
  • 2176 Answers
SOURCE: impulse gun wont fire and fan doesnt run
could be a bent probe not allowing full travel of the safety , fan motor, loose wire, or circuit assembly. If you are handy with tools, remove the battery and fuel cell. remove the 4 screws holding the cover on top of the cylinder assembly and down where the saety is remove the 2 screws there also. gently pull the cylinder off the tool. when you have apart check toe condition of the Oring on the top plate where the fan motor is. Now reinsert the battery and you will see a rocker switch towards the top, depress it and the fan motor should come on. if not try and depress the trigger switch and again the fan motor should come on. If neither start looking for loose or broken wires, if you find none then I would guess the terminal board would be bad. you can also remove the handle halves and look for a loose connection at the board itself, they sometimes wiggled loose where it plugs in. Good luck and let me know.
Posted on Apr 25, 2010
Changed the circuit board on a Paslode IM350 and now the fan wont work any Ideas welcome
fan motor could have gone bad, spark unit(little black box in handle) could be bad. one of the three top conections could be loose, or hooked up wrong, battery contacts on end of circuit board assembly could be placed a little off( battery not making contact with circuit mold assembly) pinched one of the wires going to the trigger area, or fan area
Sep 26, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350 fires every time,but nails dont come out
Unless you have the wrong nails or a problem with the feeder and/or feeder spring it is probably dirty and the driver is hanging up on the cylinder. These tools need to be cleaned and lubed after using them for some time. If you look on Paslode's website there is a manual that explains how to do it. There are also videos on YouTube that show this. It is somewhat complicated and the tool has to be disassembled quite a bit. If you don't feel comfortable doing this work then you may want to want a servicing dealer that repairs these tools. There is a rubber o-ring on the head and a filter on the top that should be replaced too. Here is a link to the cleaning guide.
Paslode IMCT cleaning guide
Aug 26, 2012 | RTO PasLode 900420 Impulse Framing Nailer
When the trigger is pressed the light on the handle flashes green and red intermittently and nothing else happens. any ideas?
Hi,I believe that is a battery issue...either it is run down or not charging properly...
Here is a tip that I wrote about the Paslodenailers and the problems that can come up with them.
I also have a link to the Paslodemanuals which contain Paslodecleaning and troubleshooting guides.
If you need parts for your Paslode,there also is a link for a site that sells the Paslode nailer parts.
PaslodeCordless Nailer Problemsheatman101
Sep 18, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
Jun 23, 2011 | Air Tools & Compressors
IM350 when battery inserted flashes green then goes to red. Tried battery in other gun and works ok. Tried full charged battery (green in other gun) and led goes red in this one. Measured voltage at 6.74v....
Check the battery contacts in the gun...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Problem with battery connection
if you remove the battery and look into where the battery goes at the bottom you will see the two prongs that make contact with the battery pack gently pry away from the side not to far but just a bit if you can not insert battery when done you pried to, far just bend them back until all works properly
Nov 11, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Aug 03, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350 has indicator light flashing red/green
The nailer’s electrical system has gone into overload protection. There may be something wrong with the fan motor or the wires going to the fan motor. Remove the cap and grill to inspect the red and black fan motor wires. If the wires are pinched or broken, that may be the problem. It may also help to disconnect the small white connector on the wire assembly that goes to the motor and then reconnect it.
Jun 22, 2009 | Tools & Hardware - Others
RTO PasLode 900420 Impulse Framing Nailer  Logo
208 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
