Question about Lionel New Haven Freight Train Set
My lionel train loses power when it hits a switch track, when the transformer is not on full power. if the train is running on full power, the light just flickers, but at 75% power, the train stops at the left handed manual switch.
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: Need help setting up Lionel North Pole Central
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Posted on Dec 04, 2009
  • 2418 Answers
SOURCE: The Cw 80 watt transformer
If you have a volt meter you can check the rails for power, Check the transformer wiring to the first rail connection and then along the rails for loss loose connection(s). If you have power to the rails it is an issue with the Engine, Check any brush or rail riders (connections) for a bent or broken tab. If for a temp fix in a broken connection tab or brush you can use Tin foil. Hope this helps.
Posted on Dec 25, 2010
  • 10 Answers
SOURCE: No longer have manual for
See link below to PDF file with instructions to your transformer. It looks like you are correct with regards to the wiring with what I can see in the manual.
Hope this helps and good luck
www.lionellines.com/files/manuals/KW_Manual.pdf
Posted on Aug 04, 2011
  • 13 Answers
SOURCE: I have a Lionel ZW transformer older version
bad track connection.... clean the track with dry scotchbite pad, then wipe with soft cloth, or the connection pins are loose in the track. tighten with needle nose pliers
Posted on Nov 20, 2011
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
My new lionel train slows down on far side of the track
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
Jan 26, 2011 | Lionel New Haven Freight Train Set
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
3 year old Lionel 4-4-2 (road number 8632) that will not run on antique track. Does anyone have any insight into whether this locomotive needs a digital power source or if it would have an issue running on...
you may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
Jan 02, 2011 | Toys
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
I have a lionel legacy cab-2 remote i hooked up every thing to the manual but when i turn it on i dont get any track power
just unplug the transformer from the grey box (the one with the green light and red light) and check the voltage. if it doesn't read anything, try unplugging the transformer from the outlet and plugging it back in again. if you get a reading, replug the transformer to the grey box and check the voltage of the silver screws (where you put the + and - wires from the track to) and try using the train again
May 30, 2010 | Lionel 14295 990 LEGACY Command Set V2
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
Lionel New Haven Freight Train Set Logo
171 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
