Question about Health & Beauty
I need a picture of a wiring diagram of a solarium cx320 tanning bed
I am having trouble after wiring the tanning bed up in the bulbs coming on and staying on,if you turn the timer on it works but fans only no bulbs come on. Can u help me
SOURCE: tanning bed setup
HI a bought a tanning bed last night from a tanning salon it was hooked threw a phone line or something like that my hubby brought it home and hooked it up here .now i cant get it to work ,will i ever see it work and how can i get it to work for me.
Posted on May 28, 2008
Gophering
  • 187 Answers
SOURCE: i need a manual for a sunual 3200 tanning bed ,i
Try this link...
www.freemanualsonline.com
Kind regards!
Posted on Sep 13, 2011
ZJLimited
  • 17970 Answers
SOURCE: i need a parts manual or wiring diagram for a
Erratic thread; but try in this link or this other.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Jul 06, 2012
emissionwiz
  • 77186 Answers
SOURCE: need a manual for esb 16 tanning bed free
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Posted on Oct 11, 2012
  • 60 Answers
SOURCE: Is tanning on a tanning bed just like tanning outside in the sun?
No - it's very different as outside, various objects block the direct rays of the sun and allow you to be outside in the sun for a lot longer. Tanning beds are very instense. You should not be on the bed for longer than 10-12 minutes for your first sessions and be very careful about adding extra time.
Posted on Feb 18, 2013
Need to get to balist on home does bottom of bed open home tanning bed 1985 sunbrella aruba 10 sontegra 12165
Have you checked to see if the very end cap of the bed qill come off accessing you to the underside of the bulbs? I would look at that and see.
Mar 07, 2016 | Health & Beauty
I have a mark i tanning bed with a token timer need wiring diagram please for tanning bed
tanning beds are no longer acceptable because they are a proven source of melanoma cancers with a high death rate of users
They concentrate UV rays that are the main cause of the cancer
Now that you still want to promote your own demise from cancer, have a electrician check the wiring out as you are not qualified to do that and simply put the power wire in to the time on to the power put wire to the timer and feel free to burn your self to death
In this country tanning beds are declared illegal and they cannot be sold , modified or imported because of the extreme problem with cancers . All tanning salons have thrown them in the junk heap
Feb 25, 2016 | Health & Beauty
Sunal tanning bed m# X144459200 In need of wiring diagram if possible The problem im having is when you power the bed all I get is a loud buzzing sound coming from the relay/contactor there is 116 volts...
The buzzing sound indicates a problem with the relay itself. It is a simple device whose purpose is to take a small amount of electricity ( like turning your timer switch on) which activates a small electromagnet coil, which then pulls down a metal contact bar which closes a switch to activate a major power consumer ( like the bank of lights on the tan bed).
The reason to do this is so you don't have like 3000 watts or more of power passing thru your timer switch which would require much beefier wiring and controls. SO by using a relay, the relay uses a small amount of power to flip a switch on the major circuit.
The relay buzzing sounds like either the coil in the relay is shorted out (the heat sometimes melts the insulation on the wires in the coil), and the short is taking away enough power from the relay magnet coil that it can't pull down the switch activation bar to switch on the bed.
If you have a voltmeter you can measure the voltage in the activated circuit that powers the bulbs. The wires should be the bigger gauge ones. If you are getting low voltage or no voltage in the secondary circuit (that is the circuit with high amps that runs the bulbs and fans) that is a good indicator the relay is bad .
If oyu know your way around basic electricity, you can isolate one of the ballasts that feed some light bulbs and hook a 110V power source to that ballast and see if some of those lights come on. If they do that is further confirmation the relay is bad and you may need to order a new one
Jan 27, 2015 | Heating & Cooling
How to replace bulbs in tanning bed
Without the specifics of your bed, I can give you some general info.
  • The first thing you need to do is remove the acrylic. Depending what type of bed you have, this may require a screw driver to remove the metal retaining strip on the outside edge of the acrylic.
  • Set the acrylic aside, & remove the burnt out bulb(s).
  • Depending on the type of bulbs you are using, you may need to place adapters on each end (these can be removed & reused from your old burnt out bulbs).
  • Regardless of bed type, most have one thing in common when it comes to bulb terminals. One end of the bed will have a stationary terminal, & one end will have a springy one.
  • Place one bulb end in the spring side first, press in, & guide the other end into the stationary side.
  • Turn bed on for a test to make sure everything is working properly.
  • Replace acrylic (and retaining strip if necessary), and you're ready to tan :)
Jan 06, 2015 | Health & Beauty
Do I need to worry about how often salons change the bulbs in their tanning beds?
Yes - even though in theory tanning bulbs can last up to 1,000 hours, if they are not changed very regularly, they can seriously affect the quality of your tan. Bulbs should be replaced after 500 - 600 hours use.
Feb 18, 2013 | Health & Beauty
Need a manual for esb 16 tanning bed free
Oct 11, 2012 | Cars & Trucks
Alisun 24 bulb 26 SXB wiring diagram
Why do you need a diagram? Tell me what the bed is doing or not doing. I may be able to help.
Jul 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Health & Beauty Logo
26 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
