Question about Canon PIXMA MP130 All-In-One InkJet Printer
'The wast ink absorber is almost full' appears what should I do?
I have a Cannon Pixma MP 130 printer which displays the message 'the waste ink absorber is almost full' when I try to print. It says to press the printers OK button to restart the printing, but this is still not working.
  • 4,041 Answers
Hello The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 11, 2010
the waste ink absorber is a small unit inside the printer where the waste ink goes in. it is a common problem in cannon printer. the ink absorber cannot be replaced mate so when it says full, buy a new printer because its not worth repairing it.
Jan 06, 2011 | Canon PIXMA iP90 Mobile Printer
Pixma MP 130/110 Printer/Copier/Scanner waste ink absorber full, It neither prints nor copies
Cleaning the waste ink pads is easy.
Are your ink tanks empty and have you been using non Canon cartridges?
Regards,
Worldvet
Aug 01, 2008 | Canon Office Equipment & Supplies
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon 130 printer ink absorber is full. need advice to fix.
Hi, is it canon 130 or canon 1300, if it is canon 1300 you can try to fix it using a manual reset and software reset. You can visit my blog here for free reseter and tutorial:
http://feedproxy.google.com/~r/Inkq-mac/~3/eJkvGfLlL1U/how-to-reset-canon-pixma-ip-series.html
To know why "waste ink absorber is full" message appear, you can visit it here:
http://feedproxy.google.com/~r/Inkq-mac/~3/0DgDreiMUw8/waste-ink-absorber-is-full.html
If the reseter won't help you please let me know. Hope this help.
Dec 22, 2009 | Canon Office Equipment & Supplies
My Cannon ip pixma 2000 is saying that the waste ink absorber is almost full how can i solve this
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
Error 8
Dear sir your problem is or E8 mean
Waste ink absorber full, or platen waste ink absorber full
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
Waste ink pad full error message
plz check the website http://www.fixyourownprinter.com/forums/inkjet/50418#1
Aug 04, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon mp 130 printer waste ink
hi
am AJAY FROM INDIA
off the printer and open upside cover,see 'the waste ink absorber if there any spunge pull that
and empty the waste ink from sponge or waste ink absorber
ok
again cloused the upside cover
ok
Jan 03, 2008 | Office Equipment & Supplies
Canon PIXMA MP130 All-In-One InkJet Printer Logo
154 people viewed this question
old marine
old marine
