Question about LG Heating & Cooling
Install window unit - LG Heating & Cooling
    Master:
    Sergeant:
  • 388 Answers
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem Air Conditioning Delray Beach
Posted on Aug 15, 2016
Plz help to get my scanner work.............. BENQ 5000B Scanner For Windows 7 32-bit
Hi ,
You need to use the install cd that came with your unit but probably it won't run under Windows 7 .
The only work around possible is to install a virtual version of Windows XP on your drive : http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Wish you good luck , otherwise you will need to purchase a compatible unit .
Regards .
Dec 14, 2014 | BenQ Office Equipment & Supplies
Drivers of ben Q scanner 5000 serial no ISHA503447SS0T
Hi ,
You need to use the install cd that came with your unit but probably it won't run beyond XP . Starting from Windows 7 ,
the only work around possible is to install a virtual version of Windows XP on your drive : http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Regards .
Jul 04, 2014 | BenQ 5000U Scan to Web Scanner
Scan benq szw 4300U windows 7 32 bits
Hi ,
Regards .
Jun 29, 2014 | BenQ Scan to Web 4300U Flatbed Scanner
We recently replaced an old window unit with a westpointe a/c mwk-08 unit. The old unit was dripping water in the house but the new unit doesn't seem to be dripping any water? Could this possible be a...
If the old unit was dripping condensate into the house, it was installed incorrectly. The replacement unit may have been installed correctly so the condensate drains outside.
Oct 04, 2012 | Heating & Cooling
Frigidaire FAC107S1A leaking water thru the inside of the house
Hello, first make sure the unit is tilted back in the window about a 1/4 inch. Also, check the drain on unit, sometimes they can clog and prevent condensate from draining.
Jul 31, 2012 | Frigidaire FAC126P1 wall/window Air...
A/C unit clatters very loud
90% of the problem with window shakers is the window that they are installed in is loss in the frame. When the unit is installed in the window you need to make sure that you install vibration eliminaters. This can be as simple as placing the foam strips between the unit and the bottom of the window you raised to install the unit through or as complex as removing the unit from its casing and reinstalling the casing, making sure all parts that touch the raised window as well as the side extensions have a cushion between them. If the clatter persists gently tap on the sash to see if you get any vibration, if so you need to insert slivers of wood between the sash and the moulding. This should solve you problem. The only thing you should hear is the compressor going on and off and the whosh of the fan.
Aug 21, 2009 | GE AGW18DH Electronic Room Air Conditioner
Installing a window A.C. unit by maytag
no it shouldn't matter,just insulate the gap so you dont loose cool air,as for the draining problem tilt it some more,and make sure drain hole is open and not plugged that should fixya
Jul 29, 2009 | Heating & Cooling
Casement Window Placement of Unit Meant for Double Hung Windows
http://www.mrslim.com/Products/Category.asp?ProductCategoryID=24
Heres an option for you I'm afraid you cant install an a/c unit In any position other than upright. Theres a unit size and type for every conceivable application though. GL!
Jun 11, 2008 | Daewoo High Energy Efficiency Air...
Window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
May 19, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
29 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
