Not exactly sure about 1999 model but It's usually located next to the oil filter with a wire coming out of it or with in the oil drain area. It's about $12 to replace.
For vehicles with an indicator light, the sending unit is like a simple switch. When the engine is off, or the pressure is too low, the switch closes, and illuminates the lamp. Under pressure, the switch is open and the lamp goes out. The only difference in the above test, is with the wire disconnected, the light is out, and with the wire grounded, the light is on. How an Oil Sender works
first need to buy oil pressure sending unit 3/8 deep socket remove oil pressure sending unit you need teflon tap sealer for oil sending unit threads.okay to replace oil pressure sending unit.you need safe raise support vechicle locate oil pressure sending unit next to the oil filter.disconnect oil pressure sending unit wire connector then use oil pressure sending unit 3/8 socket remove the sending unit.then take new oil pressure sending unit use teflon tape white plumbers tape or use thread sealer apply to the oil pressure sending unit threads then install new oil pressure sending unit and reconnect electrical connector to sending unit.then crank engine check for oil leak if all is good lower vechicle back to ground wait several minutes check engine oil level.you good to roll.
Do not run the motorcycle with out oil pressure. Fortunately, most of the time it is the oil pressure sender that is the problem. Locate the sender underneath the motor toward the front (single wire $28) and replace it with a new one. This should solve the problem. If it does not you may have to dig deeper and replace the oil pump ($125)or find the source of the oil leak. On the rare chance that the pressure relief valve is stuck open ($40). As always start with the cheap items. If you drove it home with the oil light and the cycle still runs OK then you probably just need a new sender.
The oil pressure sender is a sensor connected to your engine block. It has two wires connected to it and one is directly linked to the oil pressure gauge located on your dashboard. The sender is typically located at the front of your engine block near the fuel filter and close to the intake manifold. Applications vary, so be sure to check your owner's manual to confirm its actual location. You should have easy access to it from the front of the engine block, but you may still need to remove some parts or components to reach and replace it like the fuel filter. You'll need to detach the two wires connected to the outside, unscrew the sender from its housing, clean the gunk out of the threads in the housing, pre-seed the threads of the new sender with a light film of oil, and then screw the new oil pressure sender back into the housing. The final steps include re-attaching the two wires and any removed components like the fuel filter.
The oil pressure sender unit is located on the oil filter housing.These do tend to leak at times. The warning light for this switch is a red oil can and a buzzer. Replace the switch. If warning light still comes on, have the oil pressure checked. The oil level sender warning light is an orange oil can with oil level under it. This sender is fitted on the bottom of the oil sump and can leak past the seal. If warning light comes on, check oil level. If ok, check for damage to wiring under vehicle. Senders do some times become faulty.
