Question about Sportline 480 Tough Timer Stopwatch
Why are none of the buttons responding?
The screen is stuck, showing that it is in the counter mode, but none of the buttons respond. Removing and replacing that battery has not helped. Have tried using different combinations of holding and pressing buttons, still not responding.
Bizhub 200 touch screen is not working correctly
Utility/Counter Details Stop00 Stop02 Maintenance Mode then touch screen adjust does not work get a new control panel try web site below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 12, 2012 | Minolta bizhub 200 All-In-One Printer
None of Tv controls on side of tv will not work and remote will not work
MAY HAVE A STUCK BUTTON SUGGEST PRESSING EACH BUTTON HARD AND SEE IF ANYTHING CHANGES. THE MAIN MICRO PROCESSOR IN THE TV WILL RESPOND TO BUTTON COMMANDS BEFORE ALL ELSE SO IF THERE IS A STUCK BUTTON NO OTHER BUTTONS WILL WORK AND IT WILL NOT RESPOND TO THE REMOTE.
Dec 17, 2010 | LG 42LC2D 42 in. LCD HDTV
DEH-P940MP (Pioneer Premier ) - Button's won't respond. The volume knob works just fine but none of the buttons are working. I hit the reset button and now it is stuck in demo mode because the buttons...
have the same problem just my back screen buttons working. dont know what to do =] will try using remote for now but cant change cd. should i try reset ?? or i should not =]
Sep 15, 2010 | Pioneer Premier DEH-P960MP CD Player
Monitor shows nothing on screen, power button on solid, none of other buttons respond.
plz try by removing the connector of the monitor from the back of cpu while keeping your monitor power on. if you get any message in the monitor then your monitor is ok. then open your side cover and try by resiting the ram, you have to swithch off your pc before opening your side cover. If you dont get any thing in the monitor then *********** board is having problem
Apr 13, 2009 | Computers & Internet
Stuck in airplane mode
try a master reset of the phone...or tyake the phone adn have the flexcable replaced.
Nov 22, 2008 | Motorola Mobility RAZR V3
Black Berry 7250 not allowing me to scroll or answer calls
Sounds like you need to do a hard reset on the device. Try pulling out the battery while the device is on, leave out for 15 seconds and then put back in.
May 26, 2008 | RIM BlackBerry 7250
TOSHIBA
Hold the power button in until all lights turn off.
Apr 22, 2008 | Toshiba Satellite U205 Notebook
Key pad
A couple of things. Make sure none of your keys are stuck. One key being stuck will disable the keyboard. Carefully depress each key individually and see if one of them is responding differently.
If you want to try, and its not overly difficult, remove the keyboard and unplug and re connect every connector and ribbon cable you can find. Often one of them becomes loose or has a so so connection that can cause it not to respond.
Let me know please.
Mar 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Sportline 480 Tough Timer Stopwatch Logo
54 people viewed this question
Top Sportline Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Are you a Sportline Exercise and Fitnes Expert? Answer questions, earn points and help others
