Question about Indesit Washing Machines
Hi, indesit widl126 washer/dryer - is any master reset available?
  • 1294 Answers
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Posted on Jun 16, 2007
jaylex
  • 417 Answers
SOURCE: Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Posted on Feb 10, 2008
SOURCE: my indesit widl126s
i cant get the dryer to work i have followed all the instructions
Posted on Mar 18, 2009
SOURCE: indesit washer-dryer wd125 manual
I've been looking for these instructions and have just stumbled across them . Just inside the door there should be a barcode. On the top right check the model no. mine is WD 12S, despite the model no on the outside being WD125.
If so, look here http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WD12S.pdf
ATB
The Mighty Lev
Posted on May 24, 2009
  • 82 Answers
SOURCE: My Indesit Washer dryer WIDL126 will not work all
My guess without seeing the machine is - The motor has gone / failed.
You could get someone to check the brushes on the motor, it's only a 30 minute job.
If the brushes are ok i.e more then 10mm long, I suspect the motor has burnt out if the machine is a number of years old.
Hope this helps
jb
Posted on Jun 25, 2009
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 | Dryers
Does not drain
is it not blocked at the sump as some time this happens as it got a little door on the front if so it could be blocked hear
Dec 07, 2009 | Washing Machines
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
My Indesit Washer dryer WIDL126 will not work all the LED lights are flashing continually.I have tried turning off at the plug and then on again, but no good. Any answers please?
Hope this helps
jb
Jun 22, 2009 | Indesit W 123 Front Load Washer
Flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Indesit widl126s
Jun 15, 2007 | Indesit WA 125 Front Load Washer
no magic to it. use a pair of pliers. you are unlikely to do any damage - just the thread stiff
Apr 28, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
