Question about Electrolux Ovens
Eflp temperature
My maytag oven is showing a f3 code model #che98oobcb
The "F3" fault code is indicating an oven temperature sensor failure or a temperature sensor circuit failure. The oven temperature sensor could be open or shorted. Test the sensor for proper ohm value, frayed or pinch wiring, or connector damage. The oven temperature sensor probe can be found sticking out from the rear wall inside the oven cavity. It will need to be disconnected and tested with an ohm meter. I added a chart in the image below of the resistances of the oven sensor at specific temperatures. At normal ambient room temperature, the oven temperature sensor should have a resistance value of 1050-1100 ohms. See image below. The oven temperature sensor is part #12001655. richroth_137.jpg
Jul 21, 2011 | Maytag Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Jul 15, 2011 | Frigidaire Ovens
Get an error code of f4 when trying to set temperature
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor.
Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control
Possible Solutions:
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace. If all above is ok replace control.
Hope helps.
Jun 21, 2011 | GE Ovens
Temperature does not always reach set point of 425 F.
Oven will not hold correct temperature:------- This can be caused if temperature probe not working.Resistance across temperature probe leads at room temperature (70°F) should be approximately 1096 ohms.----------- Other possibility for this problem is :--- Temperature control not calling for heat.When heat is required, there should be continuity between terminals 6 and 7 on temperature control.-----------Inadequate or improper ventilation.Check ventilation hood. Verify draw and make up air adjustment.-----------If all this checked out ok then its calibration problem.For calibration follow this procedure:--
It can be problem with temperature controller. TEMPERATURE CONTROLLER (Standard-Control Models Only) The calibration of the temperature controller should not be changed until sufficient experience with cooking results has definitely proved that the temperature controller is not maintaining proper oven temperatures. Before any recalibration is attempted, the oven temperature should be checked by the following procedure: 1. Remove all trays and pans from the oven. 2. Place a thermocouple or a reliable mercury oven-type thermometer at the center of the middle rack. 3. Turn the oven ON and set the temperature control knob to 400°F. 4. The amber "heat on" light will go out when the oven temperature is reached. 5. Allow three cycles for the temperature to stabilize. 6. Read the thermocouple or thermometer immediately after the light goes out for the third time, and again immediately after it comes on the next time. 7. If the average of these readings varies by more than 10°F from the dial setting, recalibrate by the following procedure. Recalibration should be attempted only by a competent service technician. Use the following procedure to recalibrate the oven: 1. Loosen the two set screws that secure the temperature-control knob to the temperature-control shaft. 2. Remove the knob from the shaft, being careful not to rotate the knob or shaft. 3. Replace the knob on the shaft so that the indicator mark on the knob points directly at the temperature that was measured at the center of the oven. 4. Re-check the oven calibration. ----------- Part number for temperature probe is 1181996 and you can order if from the Southbend service center. -------- If you want the manual and wiring diagram for your oven.Please click the link directly:-- http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man ----------- after you click the link,a page will open in that you fill the 5 letter number.And click the "download now " option.It will ask you to save or discard.Click the save option and download will start.It will take 2 mins to download.Then click the download file to open it.And go through the manual.------------This will help.Thanks.Helpmech.
Jan 28, 2011 | Southbend ES10SC Electric Single Oven
Whirlpool RF375PXDN oven will not heat to desired or set temperature
The problem with the oven temperature not matching the set temperature could be caused by a bad temperature sensor. You can check the resistance of the temperature sensor with a volt/ohm meter. Unplug the range and remove the temperature sensor from the inside of the oven.Here is a link to the part.
Jan 22, 2011 | Ovens
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
F 10 code when I try using oven
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
Please rate and have a great day:)
May 18, 2009 | Kenmore Ovens
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Ovens Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
