Question about HP Jornada 540 Pocket PC
How to install windows xp step by step by boot setp in hp 540
2 Suggested Answers
prameshjana
SOURCE: i need to install win
Befor installation you need to follow the following steps
1. Start your laptop and press F10 continuously to go to BIOS setup.
2. Go to "System Configuration" -> "Device Configurations"
3. Set "SATA Native Mode" to Disabled.
4. Start the installation while keeping a finger on "F7" key.
5. After some time there will be continuous beeps.
6. Remove your finger for sometime and then continuously press "F7" key till the beeps are repeated. This is done to disable your BIOS ACPI.
7. And then do you normal Xp installation.
8. This should do
Posted on May 11, 2011
My laptop hp 540 windows xp are crrupted now how we are install windows xp tell procedure
Vikash,
You must have a CD labled Windows XP bootable.
if u have then load it in your CD or DVD drive. then you must enter into BIOS via pressing F2 or Delete Aftr that set up the BIOS for First Boot Device to CD/DVD drive instead of hard disk. save the settings in BIOS. after restart in Black screen u will get a line asking "To boot from CD press any key" press any key at that screen setup will start after that you can install the XP easily. Best of Luck
Apr 23, 2011 | Computers & Internet
I need to install win xp on hp 540 and ineed to know if i have to configer from bios or i need win xp sata support OS?
8. This should do
Jan 08, 2011 | HP Jornada 540 Pocket PC
Error message at start up. Running windows xp. HP Pavilion a700N PC desktop. The message is: This application has failed to start because hpzjrd01.dllwas not found. re-installing the applicationmay fix...
To fix hpzjrd01.dll errors occurring due to corrupt or incomplete installation of HP printer software, uninstall your printer driver and reinstall it again.
To ensure the HP printer software is completely uninstalled from your system, we recommend you either use the built-in Add or Remove Programs utility or use the help of a third-party uninstaller, such as Perfect Uninstaller.
for more information and help click here hope this helps you.
Thanks
Michel
Dec 18, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
Plz send me step by step information for removing win vist to install win xp. on compaq laptops
For ding this you need windows xp cd
put it in your CD ROM
then press F10 to get into bios and under advanced boot priority change your first option to CD and restart ,it will ask to boot from CD,press enter
You will setup process of windows xp,it will ask you where you want to install windows xp,choose drive where windows vista is installed (c:) ,then first choose the option of format this drive using NTFS,it will format your windows vista and will start installing windows xp and in an hour's time it will be done
Aug 02, 2010 | HP Compaq Presario V2000 Notebook
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
I want install windows xp on hp pc Pentuim 2 step by step
For installation of windows xp you will need windows xp bootable disk. Set the first boot device to cd/dvd and proceed with installation.
Mar 31, 2010 | HP Business Desktop dc5700 - Intel Pentium...
How can I install Winxp on HP pavilion DV5 laptop ?
You're Hard Drive may be dead. If XP is starting to install and then it goes to the Blue Screen of Death, that's most likely your problem. There's a slight chance that you're power inverter has a fluctuating power level that is causing a disruption, but that's very unlikely. Have you done any tests with any boot CD's to check the hard drive's function?
Jun 09, 2009 | HP Pavilion dv5110us Notebook
How did you install xp on your lappy I have a hp pavillion dv5-1104tu and i m wishing to install xp but i m not getting steps to install xp can anyone help me out for this problem
1. Insert the CD in the CD drive and boot up the laptop. Press F12 and select the CD as the temporary boot up device.
If you cannot get the CD to boot up with the CD, then you need to go to the BIOS configuration the change the boot order so that the CD is the first boot device (you can change it back to the hard drive later when you finish installing Windows)
2. Follow the screen instructions to install Windows. I suggest you get a computer friend to help you.
Apr 30, 2009 | HP Pavilion dv6000z Notebook
HOW TO INSTALL XP IN VISTA OS OF LAPTOP HP PAVILIION
Hi there.
The only way you can install XP on a Vista machine is to install "virtual XP" onto Vista using Virtual PC 2007.
Here is a site that will take you through the procedure step-by-step and gives links to download Virtual PC and install it onto the machine.
Please be aware that some drivers may not work whilst using XP when you have it installed.
http://lifehacker.com/software/windows/geek-to-live--run-windows-xp-inside-vista-with-virtual-pc-238071.php
Have fun, good luck and thanks for using FixYa!!
Mar 23, 2009 | HP Pavilion DV6700T Notebook
How to install window's Xp in my system
firstly..u must have cd winxp..
after u boot computer,go to cmos and select boot sequence the cd first.
after that insert the xp cd into your laptop..and reboot..
select boot from cd...press enter..
select c: enter
select leave setup.. enter..
select c
and lastly enter..
and u just follow up the question ex:language
choose your region and your language n press enter..
happy trying..
good luck
Apr 17, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Jornada 540 Pocket PC Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
