Question about Alpine CDE121
Power doesnot turn on - Alpine CDE121
Will not start starter doesnot turn over ignition
IF ITS A AUTO MAKE SURE IT IS IN PARK POS
Nov 19, 2013 | 2013 Nissan Rogue
40 duel fuel frigidaire/electrolux convection oven doesnot work self cleaner doesnot work .
Hello Walter Buford - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self-clean option or bake/broil option. If it does not turn on, then the temperature may have tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC (Electronic Oven Control) or faulty element(s). Personally, I would recommend contacting a professional for further evaluation.
Apr 14, 2013 | Electrolux Frigidaire Professional Series...
MY MECER LAPTOP DOESNOT TURN ON ONLY POWER LIGHT AND CHARGE LIGHT SHOWS
1. Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes.
2. Then try to start it up again.
May 14, 2011 | Computers & Internet
Computer was working when the power turn off and power led turns red
IT seems that the power destroy your power supply, the question now when you try to turn your computer, do you hear anything? or it doesnot turn on at all. if this is the case, replace the power supply.
Thanks for using Fixya
Oct 07, 2009 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Before i used to play games on my ps3 with de normal cable and everything went fine but recently i started using the hdmi cable but it doesnot display de menu and it directly plays the game and when i got...
when you turn on the ps3 from the back and then you hit the power button in the front hold that front power button until it beeps at you and then it will work
Sep 22, 2009 | Video Game Consoles & Games
Won't turn on..
Take off the the battery and connect the cable to your pc, and put it on, if it works this means the battery is died, if it doesnot come on try to use another charger, it seems the charger doesnot give enough power for your laptop.
Mar 16, 2009 | Computers & Internet
LCD tv power light doesnot come on.
These off brand almost always have power supply issues that have to be troublshot. $150 at a local tv repair.
Nov 18, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Presario V2000 - Does not turn on..
Hi
Have you tested your Power Adopter, it is working if yes check the battery, This may be the problem
Boopathy
Aug 10, 2008 | HP Compaq Presario V2000 Notebook
Mother board
Check you power button is unserviceable.
Open the cabinet disconnect the power On cable from front panel and short with screw driver for starting if computer is working fine. then power on switch is unserviceable,
Check the power supply also
Jul 04, 2008 | Intel Motherboard
Alpine CDE121 Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
