Black decker FSMH1621 problem
No Steam though power is on. fault finding checklist?
4 Suggested Answers
SOURCE: black & decker steam buster
Step 1 - fill the rear tank with water. Clip the tank onto the back of the unit.
Step 2 - plug the unit into the wall.
Step 3 - move the switch to "steam". You should hear the unit 'ticking' at the rate of about 120 clicks a minute (2 clicks a second). The clicking should be "kind of" loud until the water makes its way into the pump.
The clicking will get quieter as the water moves through the pump and into the heater. The book says that you should start getting steam in a couple of seconds. My experience is that you don't get a good head of steam up until the unit has been going for about 20 seconds.
Another recommendation: don't use "Spray" until the steam is really rolling out of the unit. It just overpowers the heater and slows your steam production.
Step 4 - Steam the spot you want steamed. If you want to soak the spot, use "Spray". Most of the really good cleaning power of the unit is through the steam, so use that more than spray.
Step 5 - Switch to Vacuum and **** up the moisture from the steaming.
Repeat Steps 4 and 5 until you're happy with the cleaning.
Step 6 - Empty the front tank, rinse it out. Empty the rear tank; you probably won't get all of the water out, but that's not a problem. If you use tap water, put in a couple of teaspoons of vinegar and let the unit run until you've sucked the last of the water/vinegar solution out of the tank. If you use distilled water in the rear tank, you might be able to skip this step.
Step 6 is intended to reduce the amount of lime scale that will build up in the pump over time. You should probably avoid stronger chemicals, since they are going to sit in the pump until you use the unit next, and the first few seconds of steam on the next use will have whatever chemicals you are using.
Posted on Aug 22, 2008
JULIANFIX
  • 975 Answers
SOURCE: Need a Manual
try this link , but you have to register , dont worry its free , hope you can find your manual here.
good luck AJ
http://kitchen.manualsonline.com/manuals/mfg/black_decker/black_decker_electric_steamer_product_list.html?s=fpw
Posted on May 07, 2009
vinceisaac
  • 2432 Answers
SOURCE: black and decker steam iron #415 not hot enough - why
the contact switch for heat control not get good contact or dirty need to clean.
Posted on Nov 26, 2012
Why is steam flow poor?
cause steam loss, poor pressure control and result in energy loss,transfer potential through its impact on steam flow, steam temperature, and heat energy. House Office Carpet Residential Commercial Cleaning Geelong Commercial...
g" alt="25835367-uz2mdiououqsymi0uafmfkop-1-0.png">
Aug 24, 2015 | Black and Decker USA BLACK & DECKER Steam...
Just plugged in brand new iron and the variable steam dial won't move
please take it back, it will only give you more problems. irons are not made as well as they use to be.
Jan 24, 2015 | Black and Decker USA Applica Black &...
How to fix a Black and Decker Iron?
irons are not meant to be fixed due to their construction. the cost is generally more than a new one ( if you could get the parts)
take it to an appliance service centre to determine exactly what is the fault but be prepared for a "new one" answer.
May 08, 2014 | Applica Black And Decker Steam Advantage...
How to turn it on
To switch the appliance on, press the ON/OFF button. It takes approximately 15 seconds for the steam mop to heat up. When the steam mop is first turned on, the water reservoir will glow red. Once the steam mop is ready to use the water reservoir will glow blue.
Jan 29, 2014 | Black and Decker USA BLACK & DECKER SM1620...
The steam wheel on black and decker digital advantage is stuck in the no steam position
This problem developed with our iron within the last week. Playing around with it today, I discovered that the dial WOULD respond to "persuasion". I forced it, and it cooperated. Find somebody with a stronger grip and try it.
Aug 03, 2013 | Black & Decker D2020 Iron
Black and decker steam iron #415 not hot enough - why
Nov 26, 2012 | Irons
Need a Manual
good luck AJ
May 07, 2009 | Kitchen Appliances - Others
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
