Question about Olivetti Lettera 25 Typewriter
How to lock the return on oliveitti typewriter
The peice of my typewriter that is supposed to move the paper tothe left as you type doesnt move?
It's either in the carriage lock position, just check if it's locked in place.
The other reason may be that the return spring has broken. Easy to replace & is repairable sometimes.
Jul 18, 2014 | TYPE B 1957 Royal Quiet DeLuxe Typewriter
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
Xl1500 won't type lock light flashes
Try poping off the shift and shift lock key tops to see if the springsb are damaged or sticking down.
DickyO
Aug 01, 2012 | Smith Corona Typewriter XL1500 Refurbished...
I can't get the daisy wheel inserted.
When inserting the daisy wheel, it's important to remember that the "ear" is always on the upper right side. Also need to replace the "locking lever" back to it's locked position to secure the daisy wheel. Then Press [CODE]+[RESET][Q] to return carrier to prior position. Hope this answers your question.
Nov 06, 2009 | Brother SX-4000 Typewriter
IBM Wheelwriter 6---when I turn it on, it appears to lock
There are a few possibilities. First lube the silver shaft that the carrier slides on (WD40 works well). Remove the printwheel and check for paper or ither debris in that area. After that you e
will probably need a tech.
DickyO
Jul 27, 2009 | IBM Wheelwriter 30 Typewriter
Sears typwriter
some typewriters have a carriage lock on the carriage to lock it in the center position, or it may have typet to the right margin which causes a typebar lock to activate untill you da a carriage return to the left side of the paper.
May 21, 2008 | Office Equipment & Supplies
CARRIER WON'T RETURN BACK TO THE CENTER
make it sure the cover of typewriter was lock ,self lock no movement of cover means good operation of typewriter.
Dec 20, 2007 | Brother GX-6750 Typewriter
How do you unlock a locked carriage?
The solution is not right--there is a carriage return release lever on the far right of the typewriter, that engages a notch on the underside of the roller/carriage return--push it forward to release the lever and you are in business--it has a spoon shaped end and its on the right side
Jan 24, 2006 | Olivetti Lettera 35 L Typewriter
Olivetti Lettera 25 Typewriter Logo
43 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Coss
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
