Question about Avaya Corded Phone avaparp18d
After power outage incoming calls cause all lines to light up
WE had a power outage. after the outage any incoming call on any lines causes all incoming line to light up - not possible to answer any lines
    Problem Solver:
  • 66 Answers
If this is happening on the entire system, then make sure you have the number of lines programmed correctly. If this is correct you may have a bad processor card. If this is a happening on an extension only, then the port/card may be damaged I would temporarily move the extension to another port on a different card and see if the trouble follows. If it does you have an issue with the phone not the port/card.
Posted on Nov 29, 2014
4 Suggested Answers
SOURCE: Privacy
What you are experiencing is loss of programming. Is this fixed? Could be the batteries need replacing....
Posted on Jun 03, 2008
SOURCE: receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Posted on Oct 17, 2008
SOURCE: Just upgraded to a Partner
motorola v551 imei #357264004187648 need subsidy password
Posted on Nov 11, 2009
Having trouble with my phone, went dead yesterday, I have no calls incoming or outgoing but I can text. so what is going on can you please help me.
Texts can go using wifi, calls incoming and outgoing use cellullar air time. Normally, your problems are caused by system outages or payment defaults. Has your credit card expired. Contact your carrier.
Mar 28, 2017 | Cell Phones
Error 346
There are a few causes for the errors you are getting...
The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
And here's a few things to try...
*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable the ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved.
*Try sending at a lower transmission speed.
Dec 13, 2011 | HP 920 Plain Paper Fax
When I first got my HP Officejet Pro 8500A I had no problem faxing. Now I get an error 350 code. Why? How can I fix this problem
HP's description of this error code is as follows
Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
  • Try sending at a lower transmission speed.
Sep 01, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
In trying to fax, we get Error 344
Definitions
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Aug 02, 2011 | HP Officejet 6500 Wireless All-in-One...
When I fax I get an error message 344* What does this mean and how can I get the machine to fax 5 pages at a time?
Solutions
Dec 16, 2010 | HP Officejet 6500 Wireless All-in-One...
On incoming calls rings once then stops then person calls again comes thru. also after talking sometime u can hear the system dialing? there are 7 phones in the house one has the FWD light on? could...
The first symptom of an incoming call ringing once then stopping is called trip and ring which is caused by a partial short on the phone line. The second symptom is called crosstalk caused by the two phone lines being shorted to each other. The service provider is most often the cause of these troubles. Often this type of trouble happens during wet weather or shortly after. The third symptom of static on the line cna also be caused by the same conditions. All three symptoms are likely caused by the same trouble from the service provider. Advise you report the trouble to your service provider.
Dec 09, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
Error 351
The reason for this error code is :
•The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
•The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
•The remote user pressed the Stop key while the reception was in progress.
•Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions what you can try :
•Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
•Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Try sending at a lower transmission speed
For more details you can check this link out :
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549&lang=en&cc=us&taskId=101&contentType=SupportFAQ&prodSeriesId=351105&prodTypeId=18972#Error344
Nov 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
Error 351
  • The following is for error code 351
Solutions
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Try sending at a lower transmission speed.
Mar 01, 2010 | HP FAX 1250 Fax Machine (Black)
Printer error
error message 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
OR
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved.
Dec 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Avaya Corded Phone avaparp18d Logo
82 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
