Question about Kitchen Ranges
The oven on my Frigidaire model 316065306 oven bake is hard to light. It may be on 5-7 mins. before it does and there's a big chance of an explosion form the gas we can smell. If I use the broiler first, it has to cool for a long time before I can light the bake portion. Is there a self lighting mechanism that gone bad or what?
aborcass
  • 2651 Answers
SOURCE: oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Posted on Mar 26, 2008
tzweeb
  • 318 Answers
SOURCE: Oven will not light but smell gas
i think you probably have a weak ignitor. does the ignitor glow orange?
if it does, or i should say when it does, just tap lightly on the gas valve and see if that causes the gas to flow into the burner and then light.
you can use the handle of a screwdriver to tap with and it wont need to much force.
if this does work, then just replace the ignitor. when they get weak they will glow, but wont draw enough current thru the gas valve to allow it to open. your valve does get voltage but it opens when enough current draw opens the bi-metal portion of the valve to allow gas to flow.
Posted on Jan 15, 2009
  • 165 Answers
SOURCE: my frigidaire single oven(model # FEF365BWG)
the element needs to be replaced as its not getting proper current because its got cut in between.many a times cleaning the element and refitting it again makes the device working.
Posted on Feb 20, 2009
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
  • 530 Answers
SOURCE: Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
Posted on May 28, 2009
User manual for Frigidaire oven 316065306
If you still need one I can have my dad scan his and email it to you. Let me know.
Dec 26, 2014 | Frigidaire Ovens
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
Oven not baking.
Sounds like the flame failure device is not working . or heat probe is out of position
Aug 07, 2017 | Frigidaire FGF337 Dual Fuel (Electric and...
Frigidaire oven (CFEF357CS) wont heat up after small explosion - no burn signs - surface rings and display OK - oven elements test fine
Take out the bake and broil elements and have them checked appliance places will check for free.Hope this helpsHappy Thanksgiving.
Nov 25, 2009 | Ovens
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Aug 24, 2009 | Ovens
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Our oven frigidaire model fgf367cgsd ( gas ) the burners will light... the broiler will light. but the oven will not come on.....
most common problem a faulty bake ignitor, simple enough to replace a few screws and a wire harness , not more hten 30 min worth of work, probably less then 75 dollars for the part,
Mar 23, 2008 | Kitchen Ranges
Kitchen Ranges Logo
381 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
