Question about Task Force 2000 PSI Electric Pressure Washer NEW 6127
Get parts task force 2000 electric pressure washer
Where is the in line filter and how do I take it off and check it do you have to take off the cover
the inline filter is normally at the pump connection for the hose
it is a brass gauge located under the seal ring for the connection
Apr 18, 2015 | Task Force 2000 PSI Electric Pressure...
Will not build up pressure sounds like it is but as soon as you hit the trigger pressure goes away
Is this something new happening?
These machines quickly (a matter of seconds) build up to pressure and shut off. A slow leak is not much of a player. Eventually the pressure will bleed off and the pump come on (for a few seconds).
Pressure restored, should be good to go. Have you cleaned the inline filter to the hose. If there is a short burst of water then a dribble with a new hose, the filter is a first check
Apr 17, 2015 | Task Force 2000 PSI Electric Pressure...
How do you take off hose and replace with new one
As a generic answer, there should be a black oversize hose connection looking thing where the hose joins the pump. Turn this to the left (as you face the fitting). It is oversize so you can hand tighten/untighten it, but if your hand doesn't work, try Channel locks (a fancy set of pliers.)
Nov 02, 2014 | Task Force 2000 PSI Electric Pressure...
Can i get a manual for this not syre i have all the parts grandpa passed and trying to hook up
www.pressurewashersdirect.com/manuals/CH%20electric%20manual_2.p..
www.ppe-pressure-washer-parts.com/task-force-power-washer-parts
Jul 02, 2014 | Task Force 2000 PSI Electric Pressure...
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Wont restart
    high pressure cut out switch faulty. dismantle unit dismantle and clean or adjust r replce micro switch ( on pump head )
    Apr 19, 2014 | Task Force 2000 PSI Electric Pressure...
    No water output on Task Force 2000 Motor seems
    pumps have inlet checkvalves that can be in the closed position that the hose pressure is not good enough for valves to open ther are normally behind hex screw.on pump head
    Aug 17, 2013 | Garden
    No Pressure
    Same problem here. Machine still looks brand new. Absolutely no nicks in the hose. Electric power is just fine. I hear the motor, then when I squeeze the trigger, I get a weak dribble of water for about 5 seconds, then the motor is quiet for a while. This sound familiar to you? I just posted my similar problem. If you hear anything useful, please forward it to me : reb49@att.net Ron
    Apr 30, 2013 | Task Force 2000 PSI Electric Pressure...
    Task Force 2000 PSI Electric Pressure Washer NEW 6127 Logo
    71 people viewed this question
    Top Task Force Garden Experts
    Tom Chichester
    Bill Boyd
    Are you a Task Force Garden Expert? Answer questions, earn points and help others
