Question about Garden
Bolens 2003 lawn tractor engine won't start - Garden
5 Suggested Answers
SOURCE: craftsman lawn tractor wont start
your fuel filter could be plugged
Posted on Jan 19, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
  • 5 Answers
SOURCE: My lawn tractor has started going backwards. How
manual ...www.LRNelson.com
Posted on Jul 28, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Bolens lawn tractor is blowing air out the intake. It's getting fire but won't start.
if this engine is blowing air out the carb when cranked over , i ask did the engine reciently get overheated, this sounds some what serious could be a head gasket or valve timing issue either one requires an experts hand to diagnose and fix it
does crankcase oil fill port blow oil out as well when cranked over ?
Jun 01, 2014 | Garden
Have Bolens lawn tractor, 15.5 HP B&G engine 2005
It is a fuel cutoff solinoid, backfire prevention solinoid. If it fails then you will get no gas into carburetor. If you turn the key from off to run and it clicks then it is working, if it does not click then there is a problem.
Aug 24, 2011 | Briggs & Stratton Garden
Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Bolens Q683H 8 speed lawn tractor will not go into neutral.
is the neutral safety switch located underneath the riders seat on this machine being depressed fully to make connection or could this switch be bad,if its bad the unit will not start,because the seat,transmission switch,and start circuit are in series and one that isn't closed(as in a switch) will not pass current to the start circuit
Apr 26, 2010 | Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
