Question about Pool & Spa
How do I fix my pool slide
Slide water won't come out
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Need more info how is it plummed do you have it on a controller?
Posted on Aug 25, 2014
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a Phantom. It goes into the skim mode (the top jets shoot), but won't rise to the top. Anyone????
I had the same problem. The fix is easy. The stiraphom floats inside get waterlogged and need to be replace after several years of being left in the water. The pair cost about $15 and easily slide in and out once the top cover of the phantom is removed.
Sep 16, 2012 | Hayward Phantom Pool Cleaner Complete with...
Intex Automatic Salt Water System For Above Ground Saltwater Pool won't turn on
Usualy if it is some years the ball bearing on the motor shaft are rusty and if you can desasemble and use a UD40 lubricant or similar it can be fixed, or replace the bearing. One more posible case is the starting capacitor if it replaced can run the motor again.
Jun 05, 2012 | Intex Automatic Salt Water System for ...
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
My wife and i bought a 16 by 48 in. ultra frame intex pool. we had profesionals level the ground, we have a sandy base, and after filling our pool with water and the legs settled, the pool is approx. 2 in....
There won't be any structural problems and you will notice the difference more than anyone else. If you redo the pool next year it will help to set each leg on a patio brick so it won't settle.
May 10, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
Air ring leaking on 18 foot pool....cant find leak...if it is the seam how do i fix it???
To be honest, ive seen 20-30 customers come to my company looking to fix this same problem. Weve tried vinyl patch after vinyl patch, and several different cement fixes. Nothing works.
The best results ive had are with a simple vinyl liner repair kit.
The most important thing is to let it sit for 48 hours before reinflating, but even this fix was only temporary.
Long story short, you get what you pay for, and intex is the cheapest pool systems on the market for a reason. The air ring always starts to leak right after the warranties are up, and the Intex company just plain out doesnt care.
Wish I had better news.
Mar 29, 2011 | Intex Easy Set Pool 15x36
Thermostat reads 120 degrees but pool is only about 75
Your temp sensor has gone bad. It is a small tube that slides into the water manifold with two wires comming from it. Follow these to the control board and then unplug them. Now just get a new one and replace. This should fix the problem. Good luck.
May 15, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Wont run,reads "hi", no error code. pool temp is 46F
HI is a code for Water temp over 114. If this is what you have the temp sensor has gone bad. Or thermister. It will be a small tube that slides into the water manifold with two wires coming from it. A white nut sets it in place unscrew this pull out follow the wires to unplug then slip the new one in. This should fix your problem. Good luck.
Feb 26, 2010 | Pentair Minimax NT Heater
Pool & Spa Logo
95 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
