Question about LG Task Force 6-volt Z-lite Lantern
Where can Iget replacement bulbs for a Task Force Lantern-4 pronged dual florescent 51/2inches long
Rayovac sportsman 360 lantern
It tells you on the top of the lantern if it is the 6 volt type - you unscrew the large knob, and the base will come off when it is unscrewed completely. To change the florescent bulbs, you unscrew the small knob.
Sep 06, 2013 | Camping, Backpacking & Hiking
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
I have a GE Hurricane lantern model # 17000, how do I get it apart to put new batteries in it? There is an arrow on the bottom of it pointing to oppen one way and close the other, but nothing is budging.
I have the same latern. Apply a bit more force to rotate the bottom lid in a counter-clockwise direction. There are threads on the inside of the botton lid. To replace the battery or bulb you go through the botton of the lattern.
Jun 30, 2009 | Camping, Backpacking & Hiking
Replacement Bulb For Kawasaki 19.2 Flashlight
   May I suggest taking the unit to where you purchased it and see what they say? Alph of Spokane WA.
Oct 11, 2007 | kawasaki 19.2V 4 Piece Cordless Tool Kit
LG Task Force 6-volt Z-lite Lantern Logo
415 people viewed this question
Top LG Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a LG Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
