Question about ASUS Eee 4G Notebook
Cannot connect to internet - ASUS Eee 4G Notebook
  • 115 Answers
In network connections right click the adapter you use to access the internet and select repair connection.
Posted on Jun 22, 2009
How do i connect to the internet i changed me service?
hi Inga.
see if this helps you out.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections. If your DSL or cable modem is always connected and your ISP does not require a user name and password, you do not need to run the New Connection Wizard.
How do you get access to the Internet? Internet Service Providers (ISPs) If you want to access the internet at home, you'll need an Internet Service Provider (ISP) and a router to connect to the ISP. ISPs often provide a router with their service. This means more than one computer or device in your house can use the broadband connection at the same time.
you could also go to this link and its a step by step way of finding out how to connect tp the internet,
How to connect to the internet
Nov 19, 2017 | Internet Computers & Internet
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
Hi my mxq pro 4k box is connecting but not picking up internet connection. Why Also when connected message displayed is cannot play video
The "connected" message applies to the TV, not the internet connection. To connect to the internet, either use an ethernet cable, or connect wirelessly using instructions provided.
Jul 22, 2017 | Internet Computers & Internet
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Hi, Having problems connecting the PS3 to the Internet?
There are two ways to connect to the internet there is Wireless or Wired connection here is how to do both:WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet Connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of Internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home internet access point requires a password enter the password when prompted and save your settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
How to connect PS3 to the internet?
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and saveyour settings.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
I got a Dell desktop computer from a friend who bought it new. It only has a dial up connection so I got it hooked up. Problem that I have is it won't dial out to connect to the internet. Ralphie
Hi dlwbaw
You have to make a new connection.
Go to "Control Panel", find "Network Connections", double click on that, here you choose file (in the menu) and choose "New Connection". Follow the Wizard (choose, new connection to the internet, connection without code/username/password, and normaly people have DSL connections).
Try to connect the pc to the internet now, this should work, if not:
you have to have the setup way from your internet provider, many times they have a manual on the internet. If it is a connection with user name/ code, you have to Edit your friends internet connection (icon on network connections) or make a new connection with this codes.
The codes you get from your internet provider
Some internet providers allow only one computer connected to the internet.
Hope that helps
Have a nice Sunday :O)
Please rate my answer
Sep 06, 2009 | Dell Computers & Internet
I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Jul 22, 2009 | Computers & Internet
Wireless connecting
Regarding your message, all I have to do is click on the internet Explore icon and I am connected to the internet. The wireless service is connected all of the time. My adapter connection is a VIA Rhine II Fast Ethernet Adapter. Hope that this will help you. TKS...
Jan 14, 2008 | Computers & Internet
ASUS Eee 4G Notebook Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
