Question about HP OfficeJet 7410 All-In-One InkJet Printer
Dell printer will not turn on after electrical/thunderstorm
How to factory reset dell 1320c printer
Hi Rolando,
You can download the manual copy of Printer at http://downloads.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers_color_laser/dell-1320c_user%27s%20guide_en-us.pdf
I am copied information for you. Here is the information for reset of printer.
Using the Reset button
Your printer is supplied with an electric leakage detector, which prevents electric shock or fire due to electric leakage by automatically cutting circuits inside the
printer.
When electric leakage is detected, the
Reset
button is tripped. In this case, press the
Reset
button to turn the printer back on. If the
Reset
button is tripped
again after you press the
Reset
button, contact Dell.
Check whether or not the electric leakage detector is functioning at least once a month by following the steps below:
1.
Turn on the printer, and then press the
Test
button.
l
If the
Reset
button is tripped and the printer is turned off, the electric leakage detector functions
correctly. Press the
Reset
button to turn the
printer back on.
l
If the
Reset
button is not tripped, contact Dell. Do not continue to use the printer if the electric
leakage detector is not functioning.
Let me know if issue is fixed.
Regards
VIkram
Oct 09, 2017 | Dell Office Equipment & Supplies
No dial tone
Unplug the phone cable from your computer and plug it into a telephone. If the telephone works the cable is ok. It is not uncommon to have an electrical spike come down your phone line and blow up your modem inside your computer during a thunderstorm. Get a surge supressor and put it between your line and your computer then install a new modem in your computer.
Nov 12, 2013 | Dell Computers & Internet
Printer will not turn on ,power button just blinks when you press it down.
Unplug the printer power cable from the electrical outlet. Reconnect the printer power cable into the electrical outlet, and turn on the printer.
If it does not work, contact Dell support. You probably have a faulty power source.
Mar 10, 2011 | Dell 966 All-In-One InkJet Printer
After a brief power outage during a thunderstorm my canon i9900 will not turn on. I left it un pluged for several hours and then repluged it and still nothing. Everything else in the office works fine.
The power supply of your printer are damage due to the brief power output during the thunderstorm. Just check the fuse inside of the power supply of the printer if they have some burned or else use the Multi Tester to identify that the fuse are damage or needed for replacement.
Jun 03, 2010 | Canon i9900 InkJet Photo Printer
After power outage the printer won't power up.
The printer is dead, the surge got thru and fried it. Replace it and the surge-protector.
May 08, 2010 | Dell 922 All-In-One InkJet Printer
I have a Dell 946 All in One Printer. I have
chk the power cord and bypass the surg protector
Jul 02, 2009 | Dell 946 All-In-One InkJet Printer
All day the computer was working fine-i shut it off-we had a thunderstorm and when i turned it back on tonight there is no sound now
If your computer is a Dell Dimension 1100 heres the link for the sound drivers just select your operating system and download the sound drivers This Link thats prob your problem
Jun 02, 2009 | Dell Dimension 1100 PC Desktop
Dead Dell
It is likely the power supply has suffered damage, or has just plain failed. Dell did have problems with certain power supplies in models such as the GX270, probably others too.
Anyway, if you have a voltmeter, you can check for the presence of voltages. Modern computer power supplies have a standby and main sections. I'd guess the standby portion is dead, and if so, your computer won't turn on at all. Here is a site listing the pinout & voltage spec for a typical ATX power supply: http://pinouts.ru/Power/atxpower_pinout.shtml
Note the standby line- again, this voltage will be present anytime the computer is plugged in. The main section of the power supply comes on when the power button is pressed.
If you tech savvy, you could try repairing the power supply if not toasted severely. Otherwise, a standard universal replacement might fit the bill, or just call Dell for an exact unit.
Jun 13, 2008 | Dell Dimension 4600 PC Desktop
We had left our home with the computer and printer on. A thunderstorm came up and when we got home our printer was off and we cannot get it to come back on. Help!????
you can contact any local technician as it needs a repair but the amount you will pay to the local tech would equal to two printers
you can purchase a DELL printer
you can call 1-800-999-3355(united states) and place an order for the new printer
Jun 05, 2008 | HP Office Equipment & Supplies
HP OfficeJet 7410 All-In-One InkJet Printer Logo
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
