Question about Centrios Wrist Strap Blood Pressure Monitor
Model 6308133A,,, it inflates but dooesn't show anything on the screen ?
Hi, on my JB5538 Wristech, even with brand new batteries, the unit never seems to inflate ! It developed this problem about 3 months ago out of the blue. Keep getting Err message. How do I fix it ? Th
either the compressor unit seals are damaged or you have a hole in the inflatable section either way it is not an easy fix and as they have come down in price dramatically over the past year i would suggest buying a new model & chucking this one away
Nov 12, 2014 | Health & Beauty
Why dooesn't FixYa use my Nickname?
Most likely because you used your Facebook account to register. If you want to change this you will probably need to contact Fixya.
Feb 17, 2013 | Computers & Internet
How do i bleed brake proportioning valve on chevy malibu maxx 06 i put all new calipers and bled the brakes but back rear piston still gets stuck
That dooesn,t have to do with the proportioning vavle,The caliper is defective, Was not rebuilt properly like all the rebuilt (****) You get now a days,
Nov 11, 2012 | 2006 Chevrolet Malibu Maxx
How to set up voicemail
Dial your own phone number, usually that brings you to your voicemail, and it should bring you to your voicemail options if that is correct. If this dooesn't work you should just contact the service provider and ask them.
Sep 02, 2012 | Doro PhoneEasy 410 Cell Phone
Benq model q22w6 screen goes black after a few seconds if ti is tuened off and then turned on it will work gfor 4-5 seconds and then the screen goes black
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Control the CCFL Lamps!
Aug 12, 2012 | BenQ Computers & Internet
Screen on JTX V 5 monitor has gone so dark I can not see anything. Besides it flickers on and off in the dark .
The back light is failing, and possibly the power capacitors for the HT circuit are failing to store the voltage necessary to power the screen, which would explain the flickering. This needs tested by an expert in monitors and TV's to confirm the actual source of the issue
Jul 26, 2011 | Microtech JTX V5 15" Flat Panel LCD...
Need fan motor for gemmy airblown inflatable light show. i live in michigan city of warren 48088 where can i find the part? model#TS-D-200 please help thank you thomas bogdanski
Hi, unfortunately Gemmy Industries does not sell replacement motors for their inflatable products. However, motors can be purchased at www.holidayinflatablestore.com. Although Gemmy cannot provide any support to assist you in the process, Gemmy understand that collectors of the product have been able to take care of their replacement needs by purchasing older, inexpensive units from E-bay and then transferring the parts to the newer model.
Dec 08, 2010 | Gemmy Toys
Gemmy inflatable band light show 10ft
Is the fuse inside the sound box .. does it look like the fuse in the end of the plug .. Thanks
Dec 02, 2009 | Gemmy Inflatable Polar Bear on Motorcycle
How do I get rid of the no1 that appears on the screen?
Several things here.... If you are using the electricity, you should be fine, if the battery only, check, you might have a bad one.... BUT, if all is good and only the 1-2 shows, I hate to say this, but, I had one and had to whap it on the face and it kicked it in, 'ol fashioned mechanics..... Let me know if this dows not fix it, I can call and get more answers for you..... Guy
Sep 20, 2009 | Samsung Healthy Living Bsd 3007 Deluxe...
Centrios Wrist Strap Blood Pressure Monitor Logo
35 people viewed this question
Top Centrios Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Centrios Health and Beauty Expert? Answer questions, earn points and help others
