Question about Dometic RM2652 Refrigerator
What else beside the control board could be wrong. they replaced it the fridge worked at ther shop. But when I got it home it still only works on propane.
We tried plug it into the outlet by the meter at the house that did not help the problem, changed the adapter no go. It will run for about 6 to 7 min then the check light comes on.
    Top Expert:
  • Dometic Master
  • 5,775 Answers
Sounds like you are running on LP
Posted on May 25, 2016
SOURCE: dometic rm2852 does not run on gas
So, the solution was simple but not obvious: the heat probe and the igniter are one and the same item, and all we had to do was bend the probe/igniter closer to the burner. After we did that the refrigerator started to behave properly.
Oddly enough, the repair manual for the refrigerator shows a igniter with a heat probe above it: the is not how the refrigerator is built.
Posted on Mar 24, 2009
roadrunning1
  • 152 Answers
SOURCE: Dometic fridge 'check' light keeps coming on...won't cool
Yes , the check light is there to tell you that your out of gas yes this is true but the device which switches to power is not changing over which will not let the heaters work and will not start the process of cooling, I suggest to inspect the switch and ensure that this is the case first before consulting a mechanic.
Posted on May 11, 2009
  • 46 Answers
SOURCE: royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Posted on Aug 01, 2009
  • 10 Answers
SOURCE: i have a dometic rv fridge. it works on the 120
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Posted on Feb 16, 2010
motor1258
  • 6674 Answers
SOURCE: 3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Posted on Jun 22, 2010
Pfs22mbw HI I came home and my refrig light is on
I believe that the main control board or the temp display board have gone bad. The fridge will not run without both boards working. I purchase my parts through www.appliancepartspros.com . I am unable to provide any other information as far as narrowing it down further other than replace the temp board first. Maybe another expert will have that information and can add it to my own.
Jun 02, 2017 | GE Profile PFS22MBW French Door...
Re: Lights and fan problems for Sub Zero 532 Side by side refrigerator.
First of all if you're condensor motor is controlled by electronic control board varyable speed type you might want to think about looking at replacing the control board. But first I would take a voltmeter test to see if the fan motor is getting enough voltage. If the voltage varies with the temperature inside the box then you have a controller. If the voltage remaind constant (120) and the motor still slows down yoy have a bad fan motor. As far as you're like the problem goes the only thing I can think of besides loose wires or bad switch.would be if it operated off the same control board.
Dec 10, 2012 | Refrigerators
Hi ! my 3 years old fridge Samsung Rs2630ww
lashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.
Mar 24, 2011 | Samsung RS2630WW Side by Side Refrigerator
THE FRIDGE IS NOT COOLING IN THE MAIN SECTION. CAN YOU HELP?
air blows from freezer to fridg, usually ther is a dial or lever to adjust flow, but look in freezer for any thing blocking vent to fridge, ,also mitwe be a blockage in vent
May 07, 2010 | Whirlpool 21.6 cu. ft. Top Freezer...
I have this fridge: jcd2295kes jenn-air technician replaced some control panel in the back of the fridge yesterday now temp controls are flashing PEO and 000 and fridge is not working they cant get...
For starters, use a couple of styrofoam coolers to protect your food. Then you can wait for the tech to return. The symptoms you now have are related to his work so he will want to fix it.
Feb 25, 2010 | Jenn-Air JCD2295KES Stainless Steel
Freezer not freezing, or if it is lettuce etc in fridge freezes
With fridge freezers, there is usually a solenoid at the back that controls where the refrigerent goes. It consists of a sealed valve and a solenoid coil. It is possible that this has become open circuit so cannot direct refrigerant to the freezer section.
Another alternative problem may be the thermistor in the freezer section. This sensor will tell the control board the temperature in the freezer section. If it gets it wrong, then the freezer will overcool or not cool at all. Often a manufaturer will standardise on a part, so swapping the fridge and freezer thermistors around can identify that this is the fault - then just buy another 1.
If these tests don't work, you're looking at a new control board. Second hand ones may be available.
Best of luck.
Feb 08, 2010 | Liebherr Premium K 2954 Top Freezer...
Fridge lights are buzzing and flickering
You need to replace the electrical control board. It's an easy fix. About $75 for the part. No electrical work necessary. Just unclipping and re-clipping wires into their ports. You do not need a repairman to do this! (I'm a 33 yr. old female, so please forgive my lack of technical terms in the post) I ordered one from AppliancePartsPros.com. It came in two days.
1. Pull out and UNPLUG the fridge.
2. Take out the screws that hold the bottom back panel on
(The electrical contol panel is located inside a white box attached to the lower left corner. )
3. Remove the screws that hold the box in place
5. Remove the bunch of wires out of the clip on the side of the box and pull the box out. Open it by releasing the clips on either side.
6. Disconnect the three sections of wires that plug into the board
7. Remove old board out of the housing
8. Insert new board,
9. Reverse above steps to complete installation.
Note: What triggers the buzzing sound is the door being opened. If you want to stop the sound and prevent the electrical current from going to the fried board until your new one comes, put a piece of tape tightly over the switch that pops out when the door is opened (located inside the unit near the door hinge).
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No power to ice /water in door
ther may be a fuse on the control board that is for powering up the display. look where the main power comes into the refrigerator and near by there should be a circuit board that is the brains of the unit andf on the board there should be a fuse.
Dec 20, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Fridge not working properly
the temp control got stuck during a cooling cycle if you replace the cold control it will solve the problem
Nov 20, 2007 | Refrigerators
Dometic RM2652 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
