Question about IK Multimedia Production Sonik Synth 2
Sonic synth serial - IK Multimedia Production Sonik Synth 2
How do I connect my GK3 equipped guitar to an Electric Piano or Synth ?
You cannot connect a Gk3 directly to an electric piano or synth. What you have to do is connect the 13 pin DIN connecting cable from the gk3 to the input on a Roland guitar synth unit like GR 20 or the GR 55 which supplies the desired instrument tones as required. The synth can be connected via 5 pin midi cable to an external synth to provide further tones...I personally have never used a keyboard to provide extra tones because I am a guitarist so only used synth modules and not keyboard ....remember also you need an amp or pa system to hear the sound output from the guitar synth module or external module.
Aug 30, 2015 | Electric Music
Wish to get sony sound forge 6.0 serial free for windows 7
Fixya will not give out any serial numbers, Activation Codes,
or Key Codes. It is illegal to pirate software
Jul 21, 2012 | Sonic Foundry Sound Forge 6.0 for PC
Need driver for sonic mydvd version 3
PLEASE VISIT THESE WEBSITES, I HOPE YOU WILL GET THE SOLUTION.
http://www.downloadkeeper.com/sonic-mydvd-crack-serial-download.html
http://www.brothersoft.com/downloads/sonic-my-dvd.html
Oct 03, 2009 | Sonic Computers & Internet
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
Technical
Hello
Your engine oil should be as follows
for cold climate 5W/30 semi-synth
for moderate climate 15W/40 semi-synth
for hot climate 20W/50 semi-synth
alternative moderate climate 10W/40 semi-synth
Your coolant system holds 10ltrs from empty you will be able to get this from your VW dealer (just use red or blue anti-freeze)
If its running fine on 95 benzine but you would be better putting a higher benzine in the car.
RegardsPaul
Mar 16, 2009 | 1994 Volkswagen Golf
Need help DP-01 basic hook up to synthesizer
Midi on the DP-01 is only for time synching with another device, synth, etc. To hear your synth through the DP-01 run a 1/4" patch cord from the audio outs (R and L) on your synth into the A and B inputs of your DP-01. Then assign the inputs to tracks and arm them for recording. You should then be able to hear your synth playing out of whatever you are using to monitor you DP-01 (headphones, stereo or powered monitors). To record the synth output simply press play and record together on the tascam.
bd.
Feb 21, 2009 | Tascam DP01 All-In-One Recording Package...
GP338 plus MODEL AZH38KDH9AA6 SERIAL NO 004GN4071 is giving error tone with synth unlock display
Unfortunately synthesizer unlock indicates the radio is in need of repair.
Sep 17, 2008 | Radio Communications
Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Aug 07, 2008 | Korg Mini Kp Kaoss Pad
Phone serial numer
It must be of 15 digit...... mostly starts with 35. You can see the serial number in phone also..........just press *#06#
May 21, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
IK Multimedia Production Sonik Synth 2 Logo
73 people viewed this question
Top IK Multimedia Production Computers & Internet Experts
Dan Shibata
Dan Shibata
JonSnell Electronic
JonSnell Electronic
Are you an IK Multimedia Production Computer and Internet Expert? Answer questions, earn points and help others
