Question about Canon CanoScan® LiDE 50 Flatbed Scanner
How do i use canoscan LiDE 50 with windows 7 and it says "there is no application registered for this event"
How do I use canoscan LiDE 50 scanner with my dell laptop and windows 7. when I try to scan it says "there is no application registered for this event.
  • 111 Answers
SOURCE: CanoScan LiDE 50 error code: 2,7,0
Has your scanner been working before?
If so, has anything changed since then such as new printers or other devices added to the computer, or upgraded to a new OS?
Which OS are you using?
When exactly does the error occur?
Does ScanGear open?
Are you able to preview?
Try connecting the USB cable to another port on the computer (directly to the computer...not through a HUB or any other device). Bypassing a hub, which would have to be a powered HUB, or other devices would rule out any issues with those devices.
Ultimately trying the scanner on another computer would rule out issues with the scanner as well.
Posted on May 10, 2008
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
I had the same problem more than 1 year ago and then found the solution (at least in my case that is) somewhere on the internet. Since I have the same problem with a new computer I searched the internet once more, but did not find the solution. However, last time I was so clever to write down the solution on the disk of my old laptop. The laptop is gone, but not the disk, so I could access it by putting it in an USB enclosure and was able to find the solution once again. Here it is:
c:WINDOWS wain_32CNQLxx (xx is the number of your scanner) should be included in the PATH environmental variable.
Now I know where to look for I found the link where I found it first:
http://www.everythingusb.com/forums/showthread.php?threadid=7337
The entry was by pallosp.
Posted on Nov 04, 2008
SOURCE: lide 30 deoesnt work with vista
Scan with Arcsoft PhotoStudio
It's on your disk
works perfectly!!!
Posted on Dec 18, 2008
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Posted on Jul 04, 2009
tribobenno
  • 103 Answers
SOURCE: Unable to install scanner
it does not have a windows 7 driver yet
Posted on Oct 30, 2009
I CAN`T GET MY SCANNER TO SCAN
No mention of your OS so it's only a guess; if your OS is older than the scanner, it may not have a driver to install.
Check with the Canon website for a driver for your Operating System.
Mar 15, 2015 | Canon CanoScan LiDE 25 Flatbed Scanner
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
I HAVE CANON LIDE 30 IT DOESNOT WORK IT GIVES ME A MESSAGE THAT THEIR IS NO APPLICATION REGISTERed for this event
The driver is trying to open your chosen 'image edit' (application) software (MS Paint, PhotoShop, Panintshop Pro or whatever), BUT you have uninstalled it, moved it or not chosen one ....
Go into the Control Panel, Scanners & Cameras, choose the LIDE scan driver right click for 'properties', Events tab, Select an Event pull down = 'scan start button' (or whatever) and select (browse to) your image edit package ..
Jun 11, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
WE HAVE A SCAN CANON LIDE 20 ,WE INSTALL THE DRIVER BUT IS NOT WORKING IT APPEARS THIS: There is no application registered for this event COULD YOU TELL ME PLEASE HOWCAN I SOLVE THE PROBLEM? MANY...
It sounds like the drivers were installed, but none of the application software was installed. Along with the drivers you should have received another disc with software on it. This software would be used to import scanned images and edit them, save them, or email them. If you have that disc then go ahead and install the software. If you don't have the disc you can go to the Canon website with this link and download it:
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_30#DriversAndSoftware
All you have to do is choose the operating system version you are using, and a list will come up with the software that you can download.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 21, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
CanoScan LiDE 25 Flatbed Scanner: driver for windows 7...
Drivers are available here.
Drivers and software for my LIDE 25 work fine in Windows 7.
May 18, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Oct 29, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
"there is no application registered for this event" error message
I need to reinstall on my new computer my canonscan lid 25 and misplace the cd
Oct 04, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
My conoscan650U says no application registered for this event
im hiear all u need i have got my e-mail is . walid2008dz@live.fr
Apr 20, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Lide 30 deoesnt work with vista
It's on your disk
works perfectly!!!
May 12, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon Canoscan LIDE 50
Hi am gonna provide you with the link from where you can download it, keep it mind that if you have changed operating systems, then the scanner might not be compatible with you current operating system. For instance if you had Windows ME or Windows XP but currently have Windows Vista there might be some compatibility issues. Good Luck! http://drivers.softpedia.com/progDownload/Canon-CanoScan-LiDE-Download-816.html
Jan 19, 2008 | Canon CanoScan LIDE50 Flatbed Scanner
Canon CanoScan® LiDE 50 Flatbed Scanner Logo
old marine
old marine
