Question about HP Officejet Pro L7680 All-In-One Printer
HP officejet L7680 will not print any black
New black cartridge has been installed.
Machine will still copy and print but there is no black, all other colours work ok.
There does not appear to be any error message/code on the printer display or on the computer screen.
ANy helkp gratefully received.
Thank you - Kevin Nicholls
    Sergeant:
    Champion:
  • 253 Answers
Uninstall and reinstall ur drivers and even then for our technician support contact us at http://tinyurl.com/mtgjzz
Posted on Jun 22, 2009
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP PRINTER L7680 NOT PRINTING BLACK SINCE I FITTED NEW ORIGINAL CARTRIAGE
remove the black ink , clean the contact in cartridge as well as in printer. then put back.
Sep 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Problem Printing Black
Try to reinstall your printer.
Check your black cartridge if they are installed properly.
Replace your black cartridge with a new one.
Aug 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
My HP L7680 has stopped printing black. The black cartridge is OK but I have replaced it with a new one to be sure. There is no error message but it just prints all other colours but not black?? HP...
Dear Its,
4 tray cartridge printer, i request you to please by orginal black cartridge ( No.18) and insert into the tray, def. it will start printing ...also if any damge from any relay or cartridge the printer wont work.
So the problem from cartridge only. pls try new.
Jun 28, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 the following ink cartidge(s) is missing or damaged
I have the same problem, but only with an original HP OEM cartridge that replaces the generic (which worked fine but is empty- if I put it in the error goes away- but can
t print because it is empty)
Jun 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officejet pro l7680 all in one
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Apr 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
127 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
