Measuring Tools & Sensors Logo
A
Anonymous Posted on May 07, 2014
Tx29u manual outside temp, not working
La Crosse Technology WS-9160U-IT Digital Thermometer. The outside temperature stop working. I tried new batteries.
Question edited for clarity. Full 'make model (what it is)'.
Did you put batteries in both units and in the right order, sensor first?
Step 1: Insert 2 fresh AA, batteries into the TX29U-IT sensor according to the polarity marked in the battery compartment.
Step 2: Insert 2 fresh AAA, Alkaline batteries into the wireless thermometer according to the polarity markings. Step 3: After 5 minutes place sensor outside in a shaded location.
https://www.lacrossetechnology.com/products/WS-9160U-IT#support
Retired unit so no further warranty or parts.
You can still get one on Amazon
La Crosse Technology WS-9160U-IT Digital Thermometer ...
Amazon.ca https://www.amazon.ca > Technology-WS-9160U-Digita...
Digital thermometer with wireless remote and clock; Remote sensor transmits from up to 330 feet; records daily high and low temperatures; Receives weather ...
Rating: 4.4 · ‎ 7,970 reviews · ‎ $31.50 · ‎ In stock
How to switch from centigrade to fareenheit on model TX29U
I believe that would fall under Temp Units during setup.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwj7lMTe77raAhUn8IMKHfU2BzcQFgg2MAE&url=https%3A%2F%2Fwww.lacrossetechnology.com%2Fmedia%2Fcatalog%2Fproduct%2Fw%2Fs%2Fws-9611u-it_manual_011017.pdf&usg=AOvVaw0hODvfW1eUqfE8iy61_KDF
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 • Home
La Crosse Model W86111, Setting
an atomic clock ........ no user manual ?
1 Digital Atomic Wall Clock Model: W86111 ' Quick Setup Guide
pdfstream.manualsonline.com/0/0a0678fd-f9df-4e8f-8c98-0b4794c5453c.pdf
User-Manual
content.etilize.com/User-Manual/1031159306.pd
Oct 19, 2016 • Home
Acurite weather forcaster not showing outside temp
Here's the manual for the AcuRite Weather Forecaster. If it's not showing the outside temperature, make sure the A-B-C switch is set to match the display unit. Not doing so might be the reason it's not synchronizing and displaying the outdoor temperature. https://www.acurite.com/media/manuals/75077-75107-instructions.pdf
Ambient outside air temp sensor
i may be wrong but that sensor is for the ac not for engine operation and at 113 if its not that hot then the sensor is bad but if its summer its ok,, your engine works with intake air temp
1helpful
Have a 2004 s60 volvo i have a symbol that comes on next to outside temp indicator did not come on till weather got cold
If it is a gear looking symbol (in the owners manual it is called a snowflake), it comes on when the outside temp is between 31-36 degrees F.
1helpful
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
1helpful
Outside temp sensor does not work on 1995 olds aurora
You can buy a replacement ambient air temp sensor at an auto parts store for about $10. Its as simple to change as a light bulb and can be found behind your front bumper at the base of the radiator.
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
