Question about Keurig Elite B40 Coffee Maker
Lid won't opn
Lid only opens half way. I bought some food grade lubricant and sprayed and it sill won't open. Please help
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Water sprayed due to opening
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 03, 2011
Okay, I got the lid off of my FCP280 coffee pot hooray! Is there a safe lubricant that I can use to help lift the lid off in the future? Thank you, Kathryn
Kathryn there are food grade lubricants. but any vegetable oil should work . I was going to suggest trying the lid rotating it all the way around the pot ,perhaps there is one place it just drops in and out as many older lids had a dimple in them to hold it on when pouring out hot liquid
Jan 27, 2015 | Farberware FCP280 Stainless Steel...
I have a sticky door release button. It still works but it pops back out very slow. Any idea as to how to free it up?
Clean the latch and hinges with a good detergent cleaner then lubricate with food-grade silicon spray.
Nov 14, 2014 | Microwave Ovens
Squeaking delonghi magnifica
Take it apart and clean it properly plug use sileco to lubricate for a longer use water heat coffee all of these make machine to fail
Keep service as importance
Jul 09, 2014 | DeLonghi Magnifica 3300 Espresso Machine
HI I AM LOOKING FOR A FOOD GRADE SEALANT THAT CAN BE USED ON THREADS ON A PIPE USED FOR A VERY LIGHT GRADE OIL
Here are a three places that sell food grade lubricants-
www.webstaurantstore.com/.../food-grade-lubricants-and-food-safe-lubri.
- www.lowes.com/pd_403826-75041-10340_0 and
Oct 07, 2013 | PERMATEX NON-CHLORINATED BRAKE & PARTS...
I'm looking for the fuse for the trunk for a 94 park ave my trunk lid won't shut and I believe its the fuse I show I have no power to the trunk.If you could please help me and let me know witc
you might try lubricating the trunk latch with a silicone spray or wd-40 and unlocking it with the key while it is open. There is a chance there is a small broken spring in the latch that is not pulling it over to full unlock position and when you tried to shut the trunk it is actually already in the locked position.
Apr 22, 2013 | 1994 Buick Park Avenue
The ice is being jammed in the shoot and wont come out to dispense.
Remove the jammed ice, use a hair blow dryer to dry out the chute and then spray it with PAM nonstick cooking spray. this is a food grade spray which will lubricate the chute. J.
Sep 25, 2010 | Refrigerators
My trunk will not close
There is a possibility that the remote latch cable is stuck (lubrication is gone) . With a screwdriver, NOT the fingers, try to return manually the latch, to its open position (instead of the pull open position). If you push it too far, it will go into locked position, and when you pull down the trunk lid, it wont reach its normal closed position. In that case, pull the latch back open, with the remote lever. Should you manage to close the trunk properly, spray some WD40 or some lubricant on the latch assembly.
Apr 24, 2010 | 1998 Honda Accord
GE mod #gsh22kgmb ww. port thru which ice exits
Try cleaning the edges of the flap and the ice chute as well. Once you've done that, check to see if the pivot rod is fully engaged at end side, as having it out of position could be causing it to "hang up" and not fully close.
If the rod has been knocked out of position, reposition it with your hands then you can lightly lube each end at the pivot points, with a food grade silicon lubricating spray. Use ONLY a food grade lubricant so you don't end up getting nasty tasting ice cubes or contaminating the cubes as they pass thru the chute and flap.
If that doesn't resolve the problem, you'll need to remove the chute & flap assembly from the dispenser section of the door and check for the return spring engagement, as it may have become disconnected and as a result, isn't closing the flap fully, as it should.
To do this, you'll need to remove the trim bezel around the dispenser section with a plastic putty knive (to avoid scratching the trim). be very careful when prying the bezel, do it VERY carefully so as not to snap/break the trim piece. Once you have that removed, you can see and get at the retaining screw(s) that hold the chute & flap assembly on the door panel.
Check the line drawing attached for proper part placement of the spring (part #63) and for seeing how your particular dispenser is attached to the freezer door.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GSH22KGMBWW&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-M-SERIES&diagramPageId=00004&componentDescription=FREEZER%20DOOR&documentId=G0311032&backToLink=Return%20to%20Sub%20Components%20list#partLst
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Refrigerators
Brown oily substance is leaking out of the mixer
It's the gear lubricant. It's food grade so no panic of contaminated food required. When it is all done leaking you may need to buy a new mixer or order a repair kit and open it up before the gears get ruined. - good luck- Ned-
Aug 23, 2009 | KitchenAid KSM150PS Artisan Series Stand...
How do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Dec 23, 2007 | Kenwood KM400 / KM410 Chef Classic Stand...
Keurig Elite B40 Coffee Maker Logo
12 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
