Question about LG Heat cool Window Air Conditioner
Ac window unit comporesser doesn't kick on consistantly
When i turn it on it stays on for a few minutes then kicks off and blows out side air i assume i tryed lowering the temp down to low 60's but i still can't get it to kick on it's like it only goes when it wants to not to mention it';s a few year's old so tell me what i am doing wrong please thank you
  • 158 Answers
Try switching off and on power from the plug it might reset itself
Posted on Jun 22, 2009
Could cluster fuse be prob why ac blowing hot? fan blows but hot air
Does the Compressor kick in when you turn on the AC? If it doesn't, the AC compressor is governed by the ECU. My AC went out along with an acceleration problem. hard starting, and unburnt fuel. I had my ECU rebuilt, and upon installation of the rebuilt unit, all worked perfectly again, including the AC.
Nov 08, 2012 | 1993 Lexus Ls 400
Window air conditioner cools (very icy cool air) for a minute or two then switches to fan. Will then stay on fan for about 10 minutes and then once again get "very cold", but only for a minute or two
Before I even read that far into your post, I was thinking "thermostat" replace it...It seems to be failing badly. If you take it into logical perspective...normally the unit gets turned on, then takes a bit to get cold, then once it reaches its pre-determined temperature, turns the unit either "off" or just blows the fan...by kicking off the compressor. This unit you have is getting this cycle done within 5 minutes instead of a few hours...replace the thermo and you should be fine. Now if you could post the exact model number here I can go look up the part for you.
Jun 20, 2012 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
I have a 2000 Dodge Ram 1500 that will blow cold and hot air for only a few minutes. After that is only ambient air temps. It is a 5.7 ltr, automatic with only one set of climate controls. The heater core...
you say it will blow cold and hot air for only a few minutes. You don't say but I assume you mean will blow cold a few min. when turned on AC max , blow hot only a few min. when turned to heater hot. Assuming thats the situation and you say AC charged and shows good on the low side -you should charge the AC to a full charge on the low side will cause problems with the AC air compressor kicking on and off. I suggest while the engine is running and turned to AC cold max watch the AC air compressor clutch to see if it does indeed kick on and off if so charge completely. As far as the heater make certain you coolant is all the way to the top and the best way to do this is when engine is completely cold remove radiator cap and fill completely and completely close cap then fill overflow container just to the cold level. That should fix your problem.
Sep 06, 2011 | 2001 Dodge Ram 1500 Truck 2WD
I have a 2001 Ford Mustang V6, the ac is blowing warm air. We checked the refrigerant and it is full. The ac compressor will kick on for a few seconds and then kick off. Why is the compressor not staying...
it's either low (in spite of your readings) or your a/c clutch is not working correctly or you have too big an air gap in the clutch.
First, just disconnect the 2 pin connector from the a/c pressure cycling swithc and jumper the 2 pins with a wire to force the clutch to stay engaged. See if it blows cold then, and stays engaged. You can run this way for about 15 minutes before you have to pull the plug.
report reulsts.
please don't forget to rate.
Sep 01, 2011 | 2001 Ford Mustang
Air conditioner won't stay on.
'64 could be right, but these Malibu's also have a tendency to go through HVAC head control units, among other things. I have taken the head unit out of mine and cleaned the contacts, etc...with some success. However, from what I've seen, this is just a temporary fix. These units run upwards of $200 at a dealer, but you can get one online for just over $100. It is a really easy install.
Other common problems include:
-Cruise control modules going bad (cruise kicks off at will)
-Bad resistor on fan blower (only speeds 3-5 will work)
-Front coil springs breaking
-Front brakes wear funny, excessive wear
-Moisture in headlight housings
Jul 29, 2008 | 1998 Chevrolet Malibu
LG Heat cool Window Air Conditioner Logo
155 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
