Question about Garden
What is the proper spak plug for a Ryobi model 961160002 02 lawn mower?
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
  • 8 Answers
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
SOURCE: i have a ryobi lawn mower with a 6.5 hp motor. it
I am working on one now. Customer said "it doesn't run". Ok. So, after oil/spark plug/air filter replacement...it didn't have any gas getting to the carb. Took off the bowl, and on this 2005 lawnmower, the inside of ALL of the carb was covered with a white/chalky film. Looked like tiny rust barnacles over ANY metal surface available. Silty white stuff in bowl. Blasted it all w/carb cleaner. Still couldn't get primer to work, but after I sprayed a bit o' starter in the cylinder, it started well & kept running. Until I let the bar down. Needs a new carb. Will see what the customer wants.
Posted on Jun 04, 2010
SOURCE: scott bonnar lawn mower service manual model 520...
i have a scott lawn mower,i have run it dry of fuel went to refuel.now it won't start.have cleaned the spark plug and poured fuel thru the carb any clues
Posted on Sep 21, 2010
Huaqvarna zero tarn
your switch is bad,or safety switches are scr ewed up
Apr 29, 2015 | Garden
Not getting spark in craftsman tractor lawnmower
How old is the engine? Does it have electronic ignition or points? Check the engine stop wire where it attaches to the throttle control on the engine. Make sure it is not grounding out. Has the magneto been removed? That is the Y shaped part behind the flywheel, where the spak plug wire attaches. If the mag has benn removed, it needs to be re-adjusted. The correct gap is .020 of an inch, about the thickness of a matchbook. This gap is measured between the two legs of the mag and the flywheel. I hope this helps, good luck.
May 06, 2014 | Briggs & Stratton Briggs Stratton...
Proper spark plug for homelite mdl ut2oo series weedeater
  • MFG Brand Name : Ryobi/Homelite
  • MFG Model # : AC00160
  • you can get them at any Home depot or any hardware store
Jul 04, 2011 | Homelite Mighty Lite Lawn Trimmer
I HAVE RYOBI (MTD) LAWN TRACTOR THAT HAS TWO
There should be two wires going to the seat switch. Stephen.
Nov 18, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I have a ryobi lawn mower with a 6.5 hp motor. it
Jun 30, 2009 | Garden
Replacment gas line and blub,where do i get them for a ryobi roto tiller?
From any MTD dealer. Ryobi is now owned by MTD who also owns Troy Bilt, and Bolens. Most lawn mower shops should be able to get the parts. You'll need the model number off the tiller.
Jun 27, 2009 | Ryobi Cultivator
Not enough spak-new magneto-plug-all gaps ok
Be sure you have set the magneto at the correct clearance. Make darn sure that the elements for an engine to start and run good are fuel, good air , and a good spark..That clearance by the way should be .010 to .012/ Good luck. don
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need wheel nuts and bolts for a Ryobi 21 inch 6.25HP walk behind lawn mower model #11A-546P034. Part number would be great. mtymon8019@aol.com
A good hard ware store will have the shoulder bolts you are looking for, take a wheel with you, the solid bolt part should be just a 1/16 of an inch longer than the wheel hub
Mar 21, 2009 | Garden
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
