Question about New World G70m Gas Double Oven
The top burners work fine, but the oven & grill do not?
Cannon double oven
The quality of new stuff is not as good at the old, but they are shiny and clean to start with.
With the upper burners, they have just a standard gas igniter, but you say there is no gas. This can only be cause by two things, but most likely a blocked jet for some reason. The only other reason is a faulty control.
The grill is the same, some share igniters, some have one for each of the three department, hobs, grill, ovens.
So your choice is buy a new one or get a service engineer in. It is gas, so you shouldn't really work on this on your own for safety reasons.
Feb 02, 2018 | Ovens
Hob working but grill &oven not working
Is your top burners working?
Sep 26, 2011 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Morning I need help please regarding my gas oven (Beko SCG7530). The problem is when i turn the gas knob on,(push and hold for say 10 secs)the oven works fine,but as soon as the knob is released the gas...
Sugar,
Sometimes it takes a minute or longer for the thermocouple to get hot enough to send the correct voltage to the main part of the gas valve to get it open & the burners to light. If after a few attempts of turning the pilot knob to off, waiting a couple of minutes and then going thru the lighting process, your problem is the thermocouple. Most repair companies will NOT install YOUR parts because of the liability & warranty issue. The best bet is to call a repair co & explain what the problem is & tell them to bring a thermocouple with them. Sears or calling your local BBB is your best course.
Jul 09, 2009 | Ovens
Oven glow plug on but oven wont light , dosnt get hot , top burners work fine. broiler also dosnt work . oven about 13 yrs old
if ignitor glows and the burner does not fire within 30-60 seconds it is weak (not drawing 3.5 amps or higher) and should be replaced. Hope this helps,please rate my solution
Jun 26, 2009 | GE JGRP17 Gas Single Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
New World G70m Gas Double Oven Logo
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
