Question about Bose TriPort Consumer Headphones
No sound my bose headphones just stopped giving out sound. first the left ear stopped. then the right ear went out. after this happened i waited for a little bit and plugged them back in to my computer and they worked for about 2 minutes and then gave  out again. i just tried them today about 3 days after they stopped working and its giving out nothing.
Same here..... like..... iwas using them for while by connectin em 2 my projector.. i gues.. i jus kept em aside for a few days.. whn i tried 2 use em again... it jus BLANK.... sum1 plz... totally in need of help
Posted on Oct 25, 2009
Severe squelch in left ear phone
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
My Bose QC1 Headphones have started to buzz very loudly when I turn them on. This only happens in the right ear. Are they fixable or do I throw them away?
I have a similar problem but it is the left ear. I replaced the earcup with the Bose replacement and it did not help. I would like to know if there is anything else to try
Jun 12, 2011 | Audio Players & Recorders
My left ear headset does not work. the right one is fine and the battery is charged,
sounds as if you have a short in the left ear. solution would be to send in to manufacture. Or return to the store.
Oct 04, 2010 | Bose QuietComfort 3 Acoustic Noise...
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
No sound on the left side
There are two ways that can happen...either the plug part is damaged and cannot connect correctly to the device in the jack and is only able to recieve the right side audio or, the left side speaker is blown...
You may just have to buy new headphones.
Apr 04, 2010 | Bose On-Ear Headphones
I have had the bose in-ear headphones for a year and they were great at first and then all of a sudden the left earpiece stops working. If I move the part that connects the headphones to the ipod then it...
If your headphones are in warranty (under a year old) Bose will repair or more likely replace them with a new pair. I am now on my forth pair or Bose in-ear headphones and experienced the same problem with an ear piece stop working. I have to say Bose customer service has been fantastic and has replaced each pair. Every new pair is then covered by a new full years warranty. Unfortunately my fourth pair has just gone wrong with the same connector problem. Bose again have said they will replace as they are in warranty. I have been told if they are out of warranty they will offer a new pair at a discount price of £50 instead of £80. However i think that if my new pair go wrong out of warranty i will have no option but to look at alternatives.A Pair of headphones that cost £80 should last more than a year!!!
Mar 29, 2010 | Bose in-ear headphones - Black with...
Bose on ear headphones
replace the jack,
cut the wire from the jack then replace it with new one.
remember that the
Tip - Left
Ring - Right
Sleeve - Ground
Jan 11, 2010 | Bose TriPort Consumer Headphones
My left earbud no longer produces sound! I was jogging with the earbuds and it started getting static and cutting out. I took them out thinking maybe some sweat got in them or something. I let them sit...
whatever the problem is give a call to Bose customer support(800-999-2673) and u can talk with them to get a replacement. If u r in one year warranty they will replace it(even if havnt bought it at bose store)...otherwise they will charge $50 i believe
Apr 19, 2009 | Bose in-ear headphones - Black with...
Bose QC3 makes a high pitch noise when i press it against my ear
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Jun 05, 2008 | Bose in-ear headphones - Black with...
Open Questions:
Bose TriPort Consumer Headphones Logo
342 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
