Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
How do you charge a nikon coolpix battery - Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
SOURCE: It doesn't switch ON many times though the battery is charge
I have the same problem. I can only turn the camera on once and then I have to wait a day before it will turn back on.  I discovered that if I take out the SD card, I can turn the camera on. Then (while the camera is on) I put the SD card back in.  It's a pain in the ****, but it works.
Posted on Jun 10, 2008
  • 6 Answers
SOURCE: Replacing the battery door on a Nikon CoolPix 4600
Call 3104148107 This is the Nikon Parts line, be warned it will probably take as long as 30-45 minutes of old time to get to a person.
Once you can get to a person, give them the camera model and describe the problem. They just sold me a replacement battery door for $9.95 + $6 dollars shipping and handling.
The rep was so nice he even printed out the device design blow up, and the relevant section of the manual, so I could see the step by step with out having to purchase the full blown repair manual, which runs $83.
Posted on Sep 02, 2009
  • 11967 Answers
SOURCE: coolpix nikon s710 "lens error"
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 28, 2009
SOURCE: when i turn on my
when I turn on my Nikon Coolpix S210 digital camera on it says battery temperature is high and I cannot use my camera. Why?
Posted on Feb 22, 2011
Can i charge my nikon coolpix camera through my computer ?
That depends on the model of your Nikon Coolpix camera. Some models have battery charging circuitry in them, some use a separate battery charger, and some use disposable batteries.
If you require a more specific answer, please add a comment to your question and specify the model of your Nikon Coolpix camera.
Jul 29, 2014 | Cameras
My nikon s4100 coolpix does not turn on
Hello Ice,
Please check the battery of the Nikon Coolpix 4100 Digital Camera. Please check the battery is fully charged or may be its damaged if its swollen. Also check the contact points of battery and camera and clean it. Insert the battery and charge it fully. When the battery gets charged fully then press the power button 4 to 5 times to start it. If the battery is damaged then replace the battery with new battery.
Jul 04, 2011 | Nikon Coolpix 4100 Digital Camera
Nikon coolpix 4000 not charging its shows battery exhousted
Do you have store your Nikon CoolPix 4000 battery for a long time as the battery power exhausted? If so, it maybe have cause great damage to the Li-ion Nikon camera battery, you'd better store a Li-ion camera battery about 40% power and at a place about 25 degrees Celsius
May 26, 2011 | Nikon COOLPIX L12 Digital Camera
Nikon Coolpix battery will not charge
The battery could be near the end of it's useful life. Try another one to make sure it's the battery and not the camera.
Mar 30, 2010 | Nikon Coolpix S210 Digital Camera
My nikon coolpix s220 wont charge... do i have to have the original charger???
The S220 uses the EN-EL10 battery. The camera does NOT incorporate any charging circuitry, so connecting it to a computer actually drains the battery. In order to charge the battery, you need the MH-63 battery charger or a third-party equivalent.
If you need a charger, you can order one from your local Nikon dealer or from http://www.nikonmall.com
Feb 21, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Can i plug my nikon coolpix s570 into my computer to charge battery
No. You must either remove the battery and charge it in the MH-63 charger or use a nikon coolpix s570. The best bet is to get a second spare battery so that you can recharge a spent battery.
Check
http://www.batteryengine.com/accessories/nikon_coolpix-s570_digital-camera_battery.htm
Please rate this solution. Thanks.
Feb 16, 2010 | Nikon COOLPIX S570 Digital Camera
Nikon Coolpix S2 green lamp
Check the PDF manual on the software disk to be sure Nikon Technical Support for confirmation- this is a possible replacement situation
Feb 16, 2007 | Nikon CoolPix S2 Digital Camera
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
44 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
