Question about Garden
How can I check & clean carbuerator on John Deere 335 w/ Kawasaki 20HP engine?
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
  • 183 Answers
SOURCE: John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
Posted on Apr 06, 2010
SOURCE: My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Posted on Dec 31, 2010
When P T O is engaged engine shuts down on john Deere mod. G X 335
Hi Robert, your seat switch is holding you out. try a jumper at the seat it should go good luck snor38@gmail.com
Jan 23, 2016 | John Deere Garden
How do you adjust governor on 20hp Kawasaki ohv wants to run to fast
take it to a dealer it is to sesitive to speed changes with the govenor
Sep 30, 2014 | John Deere Garden
I have a john deere tractor with a Kawasaki 20HP V-TWIN that will run on starter fluid, but will not start normaly, I replaced all the fuel related items on the engine, including rebuilding the carb,
recheck your jets also check the needle valve seat they swell up and stop fuel flow next replace the solenoid with a short bolt and try that they might sound as they are working but don't
Aug 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
John deere with 20hp v-twin briggs and stratton. starter spins but wont crank engine?
remove the starter and see if the gear broke on the starter you can buy a new gear for about $10 but make sure you get the old parts out if your lucky the gear is just stuck from sitting
Apr 22, 2012 | John Deere Garden
What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Apr 13, 2010 | Garden
Oct 02, 2009 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
