Question about Spinmaster Air Hogs Red Defender Remote Control Plane
When I plug the mains charger in to charge the 7.4v 1500mah battery the red 'charging light' does not light up ?
The red 'charging light' on the mains powered box does not light up . How do I know when it is charged ?
4 Suggested Answers
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
  • 1751 Answers
SOURCE: I plugged it in, and it has been charging for
hi
you need to let it rest for an hour and then try it again
it will work
Posted on Jan 09, 2011
busytradehoo
  • 299 Answers
SOURCE: My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Posted on Aug 13, 2012
How do you know when the battery is done charging
  1. Plug the charger into the mains, the light should come on GREEN.
  2. Now clip your battery in, the light should go to RED, indicating that the battery connected and is charging.
  3. Once the battery is fully charged, the light will go back to GREEN, indicating that the charge procedure has completed.
    Hope tis helps :)
Apr 08, 2016 | Worx Garden
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Are battery replaceble
I was able to replace the original NiCad AA batteries with a NMiH 2.4V 1500mAH (3.6 Wh) cordless phone battery Uniden BT-1015. Take out the three screws holding the back on. loosen the battery clamp, slide out the old battery and unplug it, cut off the plug on the new battery, strip each wire about 1/4 inch, push the new wires into the old wire plugs maintaining color, black to black, red to red, fasten new battery under battery clamp, adjust new battery so back of case goes on, fasten back on with original screws, charge new battery with original battery charger over night. I got my new Jensen brand battery at Meijers.
Apr 19, 2013 | Hamilton Beach 76501G Walk n Cut Can...
1500mAH VERSES 600mAH WHAT DOES THAT MEAN TO THE PHONE CHARGER
mAH is a measure of battery capacity. Assuming the battery fits, it means it'll take longer to charge fully, but then the charge will last longer.
Oct 02, 2012 | Uniden Cordless Phone
No battery light on charger on samsung st500
The rechargeable battery sounds like the main problem, but the charger needs to be checked to make sure there is not a secondary problem.
Jul 04, 2012 | Cameras
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Spinmaster Air Hogs Red Defender Remote Control Plane Logo
Top Spinmaster Toys Experts
ray gallant
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
