Question about Whirlpool AZB 7570 White Electric Dryer 7kg, 9 Cycles
I have a whirlpool azb 7570 that I purchased in Wortens in Spain. Yesterday the machine stopped working. When I select a drying program, the following 2 leds only blink: Water container Led and the Check filter LED. What should I do?
    Sergeant:
  • 479 Answers
Make sure water container is pushed all the way in and clean the filter condenser
Posted on Jun 29, 2014
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Kitchenaid dishwasher kudi24sewhi stops after filling
Hi canchild,
By your description this sounds as though the machine control board has failed. But you should test it first.
Go to Home Depot or Lowe's and pick up a non-contact voltage tester, like this one. It's a tool that you'll use more often than you think for this project and others around the home,
WARNING---> THESE TESTS REQUIRE YOU TO HAVE POWER ON! AVOID ANY EXPOSED WIRING OR ELECTRICAL TERMINALS THROUGHOUT THE TEST PHASE!!!
Now remove the 4 screws holding the kick panel to access the lower section of your dishwasher. Set the dishwasher to run a normal load and start it.
The sequence is the washer will send power to the water valve first, test this with your new tool... it should light up if the tub is empty. If it's already full, power will not be applied to the valve. When the tub is full, the board will send power to the main wash motor in about 1-2 minutes. Use your Voltstick on the main motor harness. If the board is good, your stick will light up.
Now hit "Cancel"... this should activate the drain pump (it's on the right, connected to the pump sump and has 2 wires feeding it). Again, test with the Voltstick.
NOTE---> Your Voltstick may give you false positives... avoid this by singling out individual wires to test. DON'T TEST "WIRE BUNDLES".
These tests will confirm whether or not the board is sending power to the components in question. If you have power? The components have failed OR the wiring to the components have become loose, broken or disconnected.
If you aren't getting power to the components, your board has failed and will need a replacement. The part number for it is 9743448 and lists for about $160.
Hope this helps!
SG
Posted on Apr 05, 2009
  • 77 Answers
SOURCE: Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Posted on Mar 20, 2010
heatman101
  • 43501 Answers
SOURCE: my whirlpool awz7303 is not
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 21, 2010
  • 16 Answers
SOURCE: In what year was this product initially
it was manufacted/launched on date 03/04/2011
Posted on Oct 11, 2013
How do i reset the fault code FO4 on whirlpool dryer AZB 7570.i read the manual and it says i need to call service engineer
It can only be reset after fixing the issue with the unit. Have you successfully completed the repair?
Dec 28, 2014 | Whirlpool AZB 7570 White Electric Dryer...
What format does the Pfaff 7570 use for embroidery?
The format that is used by the 7570 and the 7560 is *.pcs or *.dst. Either one will work provided that the designs are within the confines of the hoop. The largest size design that would be embroidered by this machine would be 115 x 120 MM.
Jan 03, 2013 | PfaFF Creative 7570
I have anElectrolux EDC47130W sensor dry 7kg condenser dryer. Its only a week old and worked great till yesterday. Whenever i select a program or time setting the start/pause button starts beeping and...
I think that there are errors on the program controller . As your set is new I would suggest that no tampering be done but the matter reported to the Electrolux dealer from where you had bought the machine for th privilege service under warranty.
Sometimes it might be better to register the service as the warranty gets void if tampered.
Mar 30, 2011 | Electrolux Kitchen Ranges
PFAFF 7570 User Manual
The only one I found is $40. http://www.sewingstyle.com/pfaff-7570.html You may be able to contact the site for additional information.
I think I would speak with a Pfaff dealer for information before spending this much for a manual.
Apr 27, 2010 | PfaFF Creative 7570
Ruffler for Pfaff 7570 Machine
Try contacting a pfaff dealer. If they don't have one in stock they should be able to order one for you. If you're not sure where the nearest pfaff dealer, the pfaff website should have a list of dealers for your area.
Feb 23, 2010 | PfaFF Creative 7570
Embroidery machine problem(s)
when i try to use a card with my own pattern on, the machine will not connect to the computer, it was fine until i've moved house, any ideas at all please.
May 31, 2008 | PfaFF Creative 7570
Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Apr 08, 2008 | PfaFF Creative 7570
Whirlpool AZB 7570 White Electric Dryer 7kg, 9 Cycles Logo
127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
