Question about New World G70m Gas Double Oven
The oven on my gas cooker does not ignite ( no gas ) but the 4 hobs do?
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
I CLEANED MY CANNON CARRICK COOKER TODAY AND NOW THE IGNITION WILL ONLY WORK ON THE TWO RIGHT HAND HOBS. OVEN ANG GRILL ARE FINE AND LEFT HAND HOBS CAN BE LIT WITH A MATCH.
More that likely your just got the cleaning solution you used on the igniter/in the burner. Light the burners with a match and let them burn for a little bit of time. This usually works. If not you might have to clean the igniter and make sure it is creating a spark for ignition.
Mar 07, 2011 | Ovens
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
New World G70m Gas Double Oven Logo
Top New World Ovens Experts
paulcarew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
